Terrence
- Sep 24, 2009
- 2 (0.00/day)
- San Antonio, TX
System Name | MauserPC |
Processor | AMD Phenom ii x4 @ 2.8GHz |
Motherboard | BioStar TA790GX XE |
Cooling | Stock |
Memory | 2 x 2GB Corsair XMS2 DDR2-800 @ 5-5-5-18 |
Video Card(s) | XFX Radeon HD 4850 1GB @ 685core / 1100memory |
Storage | Samsung 1TB 5400rpm w/ 32MB cache |
Display(s) | Hanns-G HH221HPB 22" Widescreen (1920x1080p) |
Case | Thermaltake M-9 |
Audio Device(s) | Integrated - Realtek HighDef Audio |
Power Supply | Raidmax 630w Modular Active |
Software | Windows 7 32-bit (Build 7260) |
Hey, I'm having a weird problem with my monitor. It's a 22" HDMI monitor by Hanns-G that displays in 1920x1080.
Whenever I start up windows, the resolution doesn't fit the entire screen. It's maybe an inch off of all four corners, inward, like it's being scaled down automatically.
I found a simple workaround to the problem, by starting up Milkdrop vis for Winamp in fullscreen mode at 1920x1080. Once I start it up then exit the vis, it'll correct the picture to the edges of the screen (and while it's displaying the vis fullscreen). From then on the picture looks fine, no blurriness like when it's scaled down, but some games that I start up (namely valve games, which reset the resolution even if it's the same res) knock it back down to the scaled form.
Any thoughts on how I can permanently fix this problem?
