Problem with monitor
Discussion in 'General Hardware' started by Tintai, Jun 10, 2013.
  1. Tintai
    Tintai
    Apr 29, 2013
    426 (0.42/day)
    69
    Poland
    Hi
    I have a horrible problem.
    When I turning on my monitor I see only white mouse on the screen. Before this I take monitor off using switch on monitor. Windows will work and I must disconnect the cable and then plug in back to fix this.
    Also the problem appears when my computer goes to standby mode.
    I have lastes drivers for graphic and monitor.
    On DVI and DL the problem is the same.
    Pleas help me...
    Thanks
    ~Tintai
  2. Vario
    Vario
    Oct 21, 2005
    3,150 (0.84/day)
    1,055
    Are you multi monitor? I see you are using a 7970.
    Rowsol says thanks.
    10 Year Member at TPU
  3. Tintai
    Tintai
    Apr 29, 2013
    426 (0.42/day)
    69
    Poland
    No I have one monitor and yes I'm using 7970.
    Maybe this is a driver problem? When I turn on I hear "buump". New device Windows sound.
    @edit:
    I remove and clean AMD drivers and instal again. Also I reinstall monitor drivers. And nothing is change.
  4. Vario
    Vario
    Oct 21, 2005
    3,150 (0.84/day)
    1,055
    I think so. Do you see a new hardware bubble on your taskbar?
    Rowsol says thanks.
  5. Tintai
    Tintai
    Apr 29, 2013
    426 (0.42/day)
    69
    Poland
    I don't see nothing bcs my monitor is black. I see only mouse. But no I didn't.
  6. Vario
    Vario
    Oct 21, 2005
    3,150 (0.84/day)
    1,055
    Do you have a second monitor you could try running as primary?
    Sorry I am grasping at straws here...
    Could you plug the monitor onto your onboard GPU?
    Boot the computer with graphics card out, then turn off. Reinstall graphics card and boot to windows with monitor attached?
    Rowsol says thanks.
  7. Tintai
    Tintai
    Apr 29, 2013
    426 (0.42/day)
    69
    Poland
    Hm I didn't try with mobo GPU, but now I plug in DVI in 60Hz and there is no problem. But I have a issue with 120Hz on DVI so I must use DL for this. But DL have a problem...
    So what do you think? This is issue with GPU or monitor or something else?
    And now I plug in both cables and DL have no problem... I don't understand this. What happens?
  8. Vario
    Vario
    Oct 21, 2005
    3,150 (0.84/day)
    1,055
    Might be a glitch in CCC, try put monitor onboard gpu, remove 7970, remove drivers with driver cleaner then reboot. Shutdown, reinstall gpu. Let windows pick drivers. See if that works?
    Rowsol says thanks.
  9. Tintai
    Tintai
    Apr 29, 2013
    426 (0.42/day)
    69
    Poland
    Maybe but I remove all drivers.
    Now this work fine but I put both cables(DVI and DL), and disable DVI. Lol it's strange.
    Maybe I must wait for official 13.6 CCC. Also, anyone have the same problem?
    @edit:
    13.6 b2 resolved this issue forever :)
  10. Vario
    Vario
    Oct 21, 2005
    3,150 (0.84/day)
    1,055
    Great. I am glad its working, sorry I couldn't help but its great that you have it resolved!
    Rowsol says thanks.
  11. Tintai
    Tintai
    Apr 29, 2013
    426 (0.42/day)
    69
    Poland
    No problem. Thanks for your interest :)
