Problem with second LCD monitor
Discussion in 'Graphics Cards' started by jds21, Jun 12, 2009.
  1. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.07/day)
    2
    Melbourne, Australia
    Something that is really pissing me off, :mad:
    I have just connected an LCD TV to my graphics card as a second LCD. I have connected it via VGA with a DVI adaptor so it can be plugged into my card. The problem is however that the colour on the TV is insanely crap! When i watch TV on it it looks great but when switching to the PC source black appears as purple.
    My nvidia 800GT recognised the monitor as a CRT which I am wondering if that may be causing the black colour to be so insanely out. This is more than just LCDs lack of black depth, as soon as I unplug the TV from my card, the screen turns its proper black colour
    I have tried adjusting every possible setting I can on both the TV and the graphics card but can't get it right.
    Is it because it is reading it as CRT that its sending a different signal or something or am I missing something here.
    Any help will be GREATLY appreciated
    jds21
  2. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.07/day)
    2
    It does have other connections so do you think I should try another?
    I might try it on another comp as well and see if it is maybe a setting on my GPU
  3. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    21,301 (6.07/day)
    7,234
    Saddly, it might just be an issue with using VGA. Does the TV have an extra HDMI port you can use instead?
  4. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.07/day)
    2
    it does but I would need to get an HDMI card because I have no output on my comp. I am willing to try it but I am just worried that I am going to buy this thing to find out it doesn't make a difference and I just spent money I didn't need to. Well I suppose it's worth a try
    Cheers, I'll see how I go with it
  5. newtekie1
    Nov 22, 2005
    21,301 (6.07/day)
    7,234
    Just buy a DVI to HDMI adaptor and an HDMI cable, your 8800GT will work just fine.
    Something like this. I realize you are in Austrailia, so you can't buy from newegg, but at least this gives you an idea of what to look for.
    You can also buy an all in one cable, like this.
    jds21 says thanks.
  6. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.07/day)
    2
    Cheers I appreciate it, fingers crossed
Share This Page
