Problem with Temp monitoring on X1650pro
Discussion in 'ATITool' started by Spyda, Feb 10, 2007.
  1. Spyda New Member
    Feb 10, 2007
    1 (0.00/day)
    0
    Hi guys,
    I've got a HIS X1650pro with iceQ (AGPx8) and I installed ATItool 0.26. There are a few problems i have :banghead: Number one is that there is no fan control and no temp monitoring at all, the log file says "Temperature monitoring: LM63 detected" so i searched it up and it should be compatible with temp monitoring.
    Second problem is that when i try to change the memory clock my screen goes blank and i have to rest my computer. I dont know if this is because its DDR2. (previously had a X800se and didnt have problems with it and ATItool)
    Third problem, well i dont know if it is a problem, but when i try to find max core clock the screen flickers with every step up and when the 3d view is open the mouse cruises :confused: (i move the mouse and stop it but it just keeps going).
    Can anyone help me out? :ohwell:
    :toast:
Share This Page
