problem with vga?
983 (0.21/day)
Memory 2x24gb Gskill 8800c38
Storage 1TB Samsung 860Evo,2*2tb Samsung 970Evo Plus, 1tb Intel 660p nvme
Display(s) Sammsung G7 32”
Case Dynamic XL
Power Supply Corsair AX1600i
Mouse Model O-
Recently, I have BSOD when play game. I sent my asus gtx 670 to RMA department,but I still have BSOD after receiving back from them.
The yellow bottom of PCI is shorter than the other, is it normal?
The yellow on the right of PCI is shorter too
I keep have nvlddmkm.sys, and dx.sys or something when play game. I have NTOSKRNL.exe while prime95+furmark to test stability. What wrong with my pc?
287 (0.07/day)
Chisinau, Moldova
System Name Winter Heater
Processor Intel Core I7 5820k@4250 Mhz
Motherboard ASUS x99 Deluxe
Cooling Cryorig H5
Memory 2x4GB Corsair Vengeance DDR4 + 2x4GB Kingston HyperX DDR4 @ 3000Mhz
Video Card(s) OEM GTX 970
Storage Seagate ST4000VN000, Hitachi 2TB, Crucial CX500 1TB
Display(s) LG 23EA63
Case Thermaltake Versa N21
Power Supply EVGA 650 GQ
Yes, the golden connectors are normal.
Did you try updating/downgrading your drivers? Update Directx. Also try running your system with only one stick of ram and test it for stability with only one stick at a time.
On a side note, did you overclock your card? If you did try reverting to stock clocks to see if that helps. Also, what are your system temps while gaming and testing for stability?
983 (0.21/day)
Case Dynamic XL
Mouse Model O-
yes, I did downgraded the vga driver and updated directx,but none worked. I tried with memtest86+ for an hour and no error found yet. I did downgraded the cpu clock to stock,but didn't work too. Temp for cpu while prime 95 is 75 C, and vga is 70 C. I was able to run smoothly for 2 years, and the problem happened like 2,3 weeks ago. I'm doubt about my PSU or mobo after RMA my VGA.
287 (0.07/day)
Chisinau, Moldova
Cooling Cryorig H5
Can you test the card in another pc? Try remembering if you changed something in your pc software or hardware since the problem appeared. I've had issues with my pc when I changed one setting in the bios and it would freeze while watching youtube videos.
983 (0.21/day)
Case Dynamic XL
Mouse Model O-
I don't have another pc. I bought another PSU and the same thing happened. Its weird because prime95,furmark,aida64,memtest86+,diskcheck don't give any crashes. Only game gives me headache;however, I'm able to play game without bluescreen when I play with window mode, when I sketch the window mode to full screen, blue screen immediately occurred. I ordered another mainboard to test this out. If mainboard doesn't help, I really have no idea how to fix it.
287 (0.07/day)
Chisinau, Moldova
Cooling Cryorig H5
Did you run those tests with each ram stick separately? Does it crash in any game? I mean do older games run fine or does it behave in the same manner? Please run the tests with only one ram module installed for both ram modules and see if it makes any difference.
1,594 (0.36/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 9 5900X / Ryzen 7 2700
Motherboard Strix B550i / B450i Aorus Pro
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair LPX 2x16 3600MHz / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Acer Z301c / 39" Panasonic HDTV
Case Corsair 2000D / Cougar QBX
Audio Device(s) Yamaha RX-V379 / Realtek ALC1220
Power Supply Corsair SF600 / BeQuiet SFX Power 2 450W
Mouse Logitech G900
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
Its either your mobo or your memory modules, I ruled that issue myself by just upgrading both XD
But I do think you should check them both out
983 (0.21/day)
Case Dynamic XL
Mouse Model O-
I have no idea now because I have no BSOD at all after turn V-Sync on and Field of View increases to 90.
9,795 (1.90/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
i agree test with other game, i think its from software, could from driver, the game or your windows
o yea, resetting bios too, sometimes it helps
