I've had a new Connect3D Radeon9550 256Mb 128 bit for a week now and I've constantly
had this problem:
When I turn on the computer it does one of two things, it either produces a couple of beeps (as
far as I know on my motherboard this means I have a problem with my graphics card) or just keeps silent. Either way, it hangs at POST without any picture on the monitor. All the fans in the case start running and the drives start up too, but then it all ends.
It seems I have the problems described by ATI at this link (without solution "of course"):
http://www.ati.com/support/infobase/4486.html
I've figured out how to temporarily circumvent the problem: after the problem occurs I just shut down the computer (power off) and then very quickly turn it on again. I know it's not good practice to do, however this is the only solution I know of.
Changing any setting (regarding AGP or anything else) within the BIOS does nothing about te problem. Removing all other components from my system doesn't help.
I've tested the Radeon in another system and it worked perfectly without problems, so I guess the card is OK. I've tried changing my PSU (400D Sunny .... kinda cheap I think, 400W max supposedly) for an Enhance PSU but had the same results. The system works fine with an older graphics card (Nvidia TNT2), so the AGP connector isn't the culprit either. 've exchanged this card at the shop already and the second one works exactly like the first one...hence the card really doesn't seem to be faulty.
Otherwise I've had no problems once the systems starts, no lock-ups, no artefacts, no freezing games or Windows.
I'd like to know if anybody solved this kind of problems (not by replacing the card with something else that is). Could flashing the card to a 9600 change anything ? Voltmodding is not an option for me, since I'm not an expert enough with electronics to try soldering something to those small contacts.
Thank you all in advance for any info and help.
My system (it's old I know, but that's life):
AMD Athlon 1200Mhz (133 FSB)
Abit KT7A
384 MB RAM PC133
Connect3D Radeon 9550 256MB 128 Bit
SoundBlaster Live ! Value
3Com Ethernet adapter
Zoltrix TV-Max tuner
had this problem:
Abit KT7A
384 MB RAM PC133
