Problems Running Ubuntu, please help
Discussion in 'Linux / BSD / Mac OS X' started by sampleera, Apr 9, 2008.
  1. sampleera New Member
    Feb 26, 2008
    21 (0.01/day)
    0
    Hey, I have a really weird problem when I boot into Ubuntu, I see the ubuntu loading screen, it loads then my screen gets all messed up [​IMG] :banghead: .
    my specs are
    MOBO - ASUS A8N-SLI
    CPU - AMD Athlon 3500+ Clawhammer
    Gpu - 2x GeForce 6800 (SLI)
    MEM - 2gb DDR
    Thank you.
  2. erocker
    Jul 19, 2006
    41,063 (11.75/day)
    16,187
    Take out one of your video cards. It should fix the problem.
    sampleera says thanks.
  3. sampleera New Member
    Feb 26, 2008
    21 (0.01/day)
    0
    I have already done This, I have tried Every Video Card Configuration and I still get that screen.
  4. strick94u
    strick94u New Member
    May 24, 2006
    1,592 (0.45/day)
    71
    Texas
    Wow it certainly looks like a config problem you have tried other resolutions right? It may be that it just don't like that card. have you tried an older version of ubuntu? I like gos which is a thin version of ubuntu and it likes both my 7900 and my fx 1300 so i don't think its a driver issue do you have another card ? Also I have seen memory do this same problem b4 that was on an AGP card but I think pci-e still uses base mem
  5. sampleera New Member
    Feb 26, 2008
    21 (0.01/day)
    0
    SOLVED!!! Someone on the ubuntu support place told me to do this
    Thanks for trying to help me though!
