Problems with 4870X2 Fan, help needed
Discussion in 'RBE' started by axon, Feb 25, 2010.
  1. axon New Member
    Feb 25, 2010
    1 (0.00/day)
    0
    Hello,
    First of all I apologize for my english, excuse me, I live in Spain.
    I've succesfully modded my BIOS using RBE 1.24, the only thing I've changed is the fan profile:
    [​IMG]
    I wanted such a profile because I'm tired of using RivaTuner (ex. when I'm on Linux it's not working, of course, and my card is really hot), there're software workarounds even in Linux but I wanted to be controlled by the BIOS.
    RBE only let me modify the fan settings of master bios (adapter 0), when I try to edit the slave bios, the Fan tab is grayed out. Is it normal?
    Ok, then I flashed it using ATIFlash, now again it only accepted adapter 0 bios... when I'm going to flash "Atiflash -p 1 adapter1.rom" it says something like "already programmed", I don't know if it's being programmed or not, anyway, if I only can edit master bios fan, maybe it's not necessary...
    When I reboot the computer I can hear how the new profile is activated, the fan spins up and down depending on the temperature (in DOS), but when I enter Windows, first it sets to 35% which is ok, the minimum temp I've configured, but when I launch a game or furmark, the profile is not working, it stays on 35% forever, even when reaching 80ยบ.... I'm a bit lost...
    Thanks to everyone.
    P.D.: I removed all ATI drivers and Riva Tuner, even using Driver Sweeper, reinstalled drivers, two times with no luck. I'm running Windows 7 Ultimate x64.
    I've also attached two bios files, the modified master one and the unmodded slave one (I used GPU-Z to extract it)
Share This Page
