Problems with graphics card and internet connection after installing heatsink and fan
Discussion in 'General Hardware' started by ThePinkPanther1, May 21, 2013.
  1. ThePinkPanther1 New Member
    May 21, 2013
    3 (0.00/day)
    0
    Hi everybody,
    I posted this on another forum previously, but so far I couldn't get a solution, so I wanted to ask you too. I hope that is fine.
    I recently installed a new fan and heat sink to my HP dv7 notebook and now have problems with my graphics card and the Internet connection.
    A short explanation of what I did:
    The fan was sounding very weird for quite some time, so I decided to replace it. I took my whole laptop apart, until I got to the old heat sink. I took it off, and cleaned the CPU as well as my AMD graphics card with some 70% alcohol until all the thermal paste was gone. I then put the new heat sink and fan in. There was pre-applied thermal paste on the heat sink. I made sure everything was nice and thigh and continued to close the laptop again. At the very end, I made a little mistake and by accident put some pressure on one of the two cables that were connected to the wireless card. The cable was a little deformed, but I was able to form it back into its original shape (I couldn't plug it in anymore at first, but when I shaped it a little bit it worked again).
    So I turned the PC on, and this was when the problems started. Here's a short description of them (In the order in which I assume they should be solved):
    Firstly: The Internet connection seems to have problems. But it's not that I can't connect to the Internet at all. If I use my browser (Opera) or want to check my emails, the connection works just fine. However, Windows reports that it cannot connect to the windows update (can provide error code if needed). Also, I noticed that when I try to for example add a contact in Skype, it will tell me it doesn't have Internet connection, although for the rest (i.e. calling somebody) it does obviously have connection.
    The wireless adapter shows in the device manager and doesn't have to experience any problems.
    Second: The graphics cards have a problem. I am using a switchable graphics card system (one graphics card is a Intel Graphics Family, the other one an AMD radeon card). From the very start, the resolution is on 800x600, which I cannot change. In the device manager, both drivers seem to have problems. The Intel one displays: "Windows has stopped working this device because it has reported problems (Code 43)" and has a yellow sign next to it. The radeon card displays "This device is disabled (Code 22)". Right after the start, I also get the message that I do not have an AMD driver installed (which I clearly had before I took out the old heat sink). If I disable the switchable graphics card option in the BIOS (i.e. I set it to fixed), I only get a black screen. Obviously, since I still have a display, there is something working, otherwise I would have the same black screen for the dynamic system for the graphics card. However, in dxdiag, there is no card selected that is managing the display right now (which confuses me a little)
    I'd greatly appreciate any help or idea on what could cause this problem!
    Thank you so much for reading.
  2. caleb
    Sep 15, 2004
    1,561 (0.37/day)
    208
    Poland,Slask
    Hello, things that come to my mind :
    - too much pressure by the new heat sink mount
    - some thermal paste got onto circuits
    - you broke/shortened something with that cable deformation
    10 Year Member at TPU
  3. theoneandonlymrk
    theoneandonlymrk
    Mar 10, 2010
    3,597 (1.66/day)
    660
    Manchester uk
    Download and install the latest drivers ftom amd and your laptop maker and install malwarebytes anti malware and run it as your internet issue could be virus related due to its oddness.
    More than 25k PPD
  4. ThePinkPanther1 New Member
    May 21, 2013
    3 (0.00/day)
    0
    Thanks for the quick help everybody!
    Just a short update: I resolved the issue with the internet connection. It was because the clock was set to the wrong time (I guess because the bios was confused about being taken off or something).
    I will try to download the drivers manually later today. I do not think that there is too much pressure on the graphics card or cpu (the screws didn't allow to be any more secured as to a certain point, which was exactly the same with the old (same model) fan. But what would I do about that, if that was the case?
  5. Black.Raven
    Black.Raven
    Jun 28, 2012
    217 (0.16/day)
    93
    Bios stores time and boot configuration. so after pulling it out and putting it back in, its on its default settings again. Good time is very important, because most sites have certificates that have an expiring date.
    Crunching for Team TPU
  6. ThePinkPanther1 New Member
    May 21, 2013
    3 (0.00/day)
    0
    Ok, so I now installed the new drivers. Now the resolution is back to normal and everything from that point of view seems fine. Thank you so much!
    However, I came across a new problem, now that I can run programs again. Namely, the memory usage of most programs seems too high. Right now, I am only running my browser (Opera) still, my memory usage is at 35%. Any idea on what might have caused that? Is there a way for me to see which programs are using up the memory? (I can't imagine opera and the system alone taking 35%..)
    EDIT: I found out how to check what is using up memory. My problem now is the following: there are some programs using a lot of memory (the highest right now is by opera, 100'000 K.) In total, they use up around 2 GB of ram on startup. But the problem is: I did not make any changes to my software since I installed the new heat sink, and I checked for viruses (which I did not find). Yet, the memory usage seems to be a lot higher than just before installing the new heat sink. (I.e. before I was able to run opera, skype (calling somebody with video) and play an online game at the same time. Now the PC starts to lag heavily already when I chat with somebody using camera. This seems very odd to me, and I haven't really got an idea on how to solve it (I tried starting disabling the processes that use the memory, but on the one hand I need some of those (my browser for example) and on the other hand they all could run just before installing the heat sink, so I don't really get why now they should not be able to.)
    Could this be related to taking out the memory and putting it back in? (I might have messed up the position of which ram was where)
