Two updates in one day? Crazy, isn't it? Well, as promised, I'm moving on to the switch plate. For any of you that remember when I was putting the mesh in the case cover, you'll have noticed that the switches were in a non-traditional location. They are on the right side of the case, and to facilitate their placement, a custom bracket was needed.
So, I marked out the pattern I needed in a piece of aluminum, and I was ready to cut.
A little quick Dremel work, and then some time on the metal brake resulted in this...
A quick test fit indicated I could move on to the next step. It fit exactly as it should.
Next I had to mark out the switch locations.
Once drilled and Dremeled, I was left with dropping the switch and an USB port in place. Like a glove!
With a high strength epoxy applied, the bracket was clamped in place.
One day later, and the epoxy was cured. The clamps were removed, and believe me when I say, that bracket won't be coming off anytime soon... okay, ever...
So, what's next at this point? Well, good question. All major pieces are now in place. I've got no real fabrication left. Hutch and I are still contemplating a good reservoir idea, but other than that, it's all down to details now. I've got wire sleeving to do, as well as hose routing. Also, who could forget the paint? Colors aren't definite, but the interior will be black, while the outside will be a complementing color. Sure, we'll also likely slip in some other small details here and there, but this is really the bulk of it. Of course I'll continue to post as work progresses, but for now, we've got the clean and solid foundation we were looking for. There's no bling, or extraneous fluff here. So, for anyone expecting
Project: Rogue type insanity, stick around for the official start of
OSIDIAS soon!
