holy hatrick. may the gods of cable management help you
you are going to run those underneath right ?
shame to spoil the effort thus far with the evil cable monster
Haha, yes most of the cables will be run underneath the mobo, I'm gonna try to use some for accenting since the UV tubes will be in there, if I can make it look good I think it will be pretty cool. Some cables need to be shortened, some need to be re-sleeved; I ran out of sleeving so it should be here tomorrow. I wanted to get the desk together so I could do some heat tests and layout cable management for the power cables/usb cables.
I will be getting a few other things as well:
3/8" Nylon Cable Sleeve - UV Superhero
1/2" Orange Heatshrink
Customizable Standard 4 Pin Extention Cable 18"
Lian Li Motherboard Thumb Screw Kit - Black - 12 Pack
Brass Stud Coarse Thread Standoff
Blow Off Contact Cleaner
Bitspower X-Station Power Extension I - Orange LED
1/4" Nylon Cable Sleeve - Orange
Standard 4-pin Female Connector - UV Bright Orange
Standard 4-pin Male Connector - UV Bright Orange
12" Cold Cathode Kit (Dual Ready) - Ultra Bright UV
2 x 15" Deluxe Sound Activate Cold Cathode Kit - UV
Logisys Inverter Harness Cable w/ Rocker Switch
Lamptron 4 Channel High Output Aluminum Cathode Inverter - 4 Tubes Off One Inverter
Fan Screw - Black
1/4" thick piece of 12"x12" rubber so I can remove those ugly stands that are holding the glass.
Thanks to Ultimate Desk for sending this over to me, will now be able to securely attach my PSU to the acrylic on the side:
Mess? Pfft, that's normal to me.
It's definitely coming along nicely though. I think it would look great if you ghosted that DVD drive.
What do you mean ghosted? Thanks for the kind words along the way duder
Today my buddy is attempting to make this awesome fan cutout on the piece of acrylic I gave him, so if it doesn't crack in the machine it should look awesome. Even if it does I'll be ordering UV Orange acrylic down the road and leeching an idea from l3p by having my mousepad glow and putting it under a cup holder, so he can try again. Looked really good on his build and since I'll have 4 UV tubes in this desk it should make it glow nicely.
For reading all that you get some pics, enjoy!
