Project Thief - CaseLabs TX10-D Dual Workstation/Gaming Build - Gulftown and SB-E
211 (0.05/day)
Hey everyone - it's been a while. Moving house soon so all I've really done is assemble some parts and do some sleeving. Here's the 24 pin extension. Eventually the PSU will get full sleeeve, but extensions can be trained better, so let's do those first.
Getting ready - cut the wire last night:
Getting my crimp on...
Males done:
Stripping:
Females done so now we our crimping is double-ended:
Heatshrinkless FTW:
Details:
Should have cut the outer run longer than the inner wire otherwise this happens:
I'll either redo or just train the extension to have a hidden double kink that should take it out.
Making progress:
My fingers are definitely burned now:
And done:
Daylight pics:
de.das.dude
Pro Indian Modder
8,756 (1.74/day)
Stuck in a PC. halp.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
you still here.... :p
211 (0.05/day)
Yeah and I think it'll be a while longer yet:
Here's some more after finishing up a 6 pin and 8 pin extension, mostly taken at the same time, shot freehand with the incandescent setting:
Also today I finally put the right memory in the gaming rig:
This case now has 14 sticks Dominator GTs running... still needs the memory block and the right fittings though!
Then I messed about with the camera:
Didn't quite work out, but thought I'd share anyway :)
HammerON
The Watchful Moderator
8,397 (1.52/day)
Up North
System Name Threadripper
Processor 3960X
Motherboard ASUS ROG Strix TRX40-XE
Cooling XSPC Raystorm Neo (sTR4) Water Block
Memory G. Skill Trident Z Neo 64 GB 3600
Video Card(s) PNY RTX 4090
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard Corsair K70
I see you are using a lot more quick disconnects for this build:)
9,762 (1.91/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
looks pretty good and solid with no heat shrink ::cool::
211 (0.05/day)
Haha yeah just a few :)
MEGA POST!
So it's been a while. Not much progress on the build because I've been busy moving house, securing more sponsors for this build (see below) and getting review samples for future reviews as well as finishing existing reviews. I finally wrapped up my 17 cpu water block roundup which is posted on my website(extremerigs.net) and XS. Next I'm working on a pump/top/res roundup and a Titan water block roundup. In between I'll be slowly finishing this build. So here's everything that's happened in the last two months, some of which is relevant to the build and some of it isn't, but I figured I'd include all of it anyway.
Koolance sent some stuff - this is all for review though rather than this build:
PMP500, a D5 top and integerated 120mmx70mm (fat) reservoir and a bunch of the new QD style QDCs:
Let's start with the D5 Top:
This is a full cover top that completely encloses the pump unlike the EK one that is just a top. A cylinder reservoir can also be mounted directly to the top if you want. With Bitspower you can buy a top and a seperate dress kit but the Koolance has all of it included:
It comes with mounting brackets and plastic thing that I'm not sure yet as to the purpose!
The top is pretty serious and bulky like most D5 tops. If you want small, stick with a DDC style pump:
The reservoir that Koolance sent is their "fat" 70mm ID variety which needs adapters to fit to the pump top:
This should not be used for a frosty beverage:
You can see the threaded adpater which will screw into the pump top. The pump top comes with a base adapter for a "normal" size reservoir.
Here it is fitted - the size actually works because the D5 top is so bulky:
Obviously the ftting at the top of the pump top would need to be removed and moved to the side inlet port. One thing I don't like is that this means you have to use the top port of the reservoir as your return line. I prefer to have that as the fill port.
They also sent a PMP500 for review. This is their all new design that is much more powerful than a D5 or DDC pump:
Came with no instructions:
A mounting bracket and some screws but nothing else:
Integrated heatsink and nice looking top, but the two halves do clash a little in style:
It is however very compact for a more powerful pump. A D5 with a top is considerably larger:
I'll also be reviewing the new QDC's. I'd used the VL4N and VL3N's for a while and my main complaint was that the female connectors were sensitive to being bent out of shape when dropped. The new design should be more robust:
The QD4 series is the larger size that is more designed for industry than us guys. It is marketed as a direct replacement to the VL4N. It's larger and lower restriction than the QD3 and has fewer useful connection options. They do however come better packed:
No way these things will be damaged in transport. The business ends:
Connected - you simply push the two together:
Disconnected - you simply pull the ring labelled pull:
I have to admit I prefer the new mechanism - there's less time in the zone of being partially open, these really snap on and snap off quickly. No rotation is also a good thing as it lowers the risk of the other end of the tube becoming unscrewed.
The QD4 comes with two options for the other end - either 1/2" ID 3/4" OD compression fitting or a male g 3/8" fitting. Note that this is not a standard g 1/4 like 99% of computer water cooling components.
However Koolance have an adapter ready for you if you do wish to use these:
It barely adds anything to the length unlike the alphacool adapters that I've used in the past. I also like that they've included wrench flats on the threaded version:
Because these are lower restriction they are more bulky and will not fit on a block even with widely spaced ports like their own CPU-380:
The QD3 series on the other hand is designed for computer enthusiasts. It's smaller and replaces the VL3N line up. These instead get packaged like normal fittings but with a protective rubber.... sheath on the quick disconnect end:
Those were the 1/2" ID 3/4" OD compression fitting ends. These are the male g1/4 threaded:
One of each with their rubber... booties on:
The quick disconnect part is much smaller:
Unlike the QD4's these can be directly mounted on most blocks that can fit 3/4" OD compression fittings as the compression fitting lock ring is the widest part of the QDC:
QDD3 vs QD4:
EK are sponsoring the build so a big thanks to them but also sent some stuff for review in the upcoming pump/res/top roundup:
The RP452x2 I have will actually be removed and replaced with the 400mm reservoirs that EK already sent me earlier in the year:
That RP452x2 will be part of the roundup though lol. EK sent me lots of coolant:
I was trying to take a cooler shot - but it kinda looks like I'm bragging about my car so :shrug:
DDC top - this replaced the XSPC acrylic one that I have so that all my pumps/reservoirs are consistently EK:
Unboxing -
I do love EK's packaging, the best out there to be honest and it makes you feel like you bought a quality product:
Individual baggies:
Sealed with a logo:
There's been a lot of hate on those circles, but EK are changing their designs now thanks to the thinkcell voting:
I have to admit I'm a sucker for the details though:
Not much detail on the inside:
You can see the slight angle upwards to the port:
White D5 top - this replaces my old style EK Black D5 top:
Taking it's shirt off:
White on white is hard to see:
So let's see it on a metallic grey background:
I think this one unlike the DDC has a few too many circles
Do you spot the white theme:
These will be on the workstation side representing the public "light" image of the thief, vs the gaming side representing the hidden "dark" side of the thief. There is some variation in the white acetal color but it's pretty minor. Hopefully it won't be noticeable:
Lovely detail on the inside though it's hard to see:
Now for that white reservoir that I posted an unedited version of this pic:
Well let's do it properly now:
Comes bubble wrapped and with an optional filter
All the accessories - sadly the mounting clips are still black:
The base has 5 ports on all versions. The difference between the basic and advanced is instead the top. On the basic it only has one port. That's ok for me. I like to use the top as a fill port only and have the return in the base:
The anti cyclone works, however bleeding is slightly faster if you use a long tube instead to prevent the bubbles getting back in the outlet:
Dual D5 top - this replaces the bitspower one that I have, but never got to put in build. This will actually replace the Koolance RP452x2 that I'm using right now. Anything pump/top/reservoir will be reviewed in the upcoming roundup lol:
Underside of the top:
Top of the top, only a few circles:
With the clamp plate that holds the D5 on added:
This one is just for review not the build:
2 bay res with integrated DCP 2.2 pump:
Lots of circles:
The bottom bay of the res is actually pretty useless, it's really just filling up the space around the pump:
Lutro0's sponsorship package arrived so that I can finish my sleeving. Got a fancy wire stripper:
It was a bit dusty in the box but who cares about that:
Lutro0's crimper. Supposedly the same as MDPC's but with a bit of milling to make it usable with AWG16. I need to get my MDPC one out to compare:
Comes with two example crimps just like Nils sends:
Flush edge cutters for cutting sleeve *not* wire:
though you can use them for wire, you'll want a 2nd pair for that so they stay sharp:
Molex pin extractor:
Crimps and connectors:
Lots of wire - each one is one spool, I'm not sure why it wasn't left on the spool? Maybe so it is easier to train? I'm going to ask Lutro0 when I get some time.
And an example 24pin extension from the man himself:
Also picked up this fan as a test to see how quiet it can go. I'm thinking of changing out all the fans now and running uber silent now that my long term plan is to use the front bays for 4x360 rads
Goes down to ~400rpm and Martin recommended it as being very quiet:
Also got this as a tester because to be honest LED fans are cooler than white ones:
PWM but only goes to 600rpm and is allegedly a bit buzzy
Has a switch for the LEDs
Also figured I should try PWM control of the existing gentle typhoons and yates in case it's the same volume and I can make my life easier, so I got one of these. Also recommended by Martin:
I got the smallest one that fits in a 3.5 bay but there is a 6 channel one that takes up one 5 1/4" bay:
If I end up using it I will be hiding it because it is pretty ugly:
Welcome to Alphacool also who are sponsoring the build. They sent me some rads as well as other stuff for review:
The monsta'st monsta:
Hard to photo because it's so big:
It's big. Next to an XSPC RX360 with push pull fans:
Comes with copper accessories which sadly don't match my build:
Also the sexy full copper UT60 in white:
Get ready:
Cause it's hot:
And it makes me want to take off all my clothes:
Also the full copper 45mm thick 560 known as the XT45:
Still bubble wrapped - I spot a pattern:
A 45mm rad doesn't normally look thin, but 560's are so big that it does:
Next to the monsta:
Also a thin 360mm, thin is useful for the side mount next to the PSUs where I don't have much room:
This puppy is 30mm thick:
Looks skinny next to a 60mm UT60 which itself is skinny compared to the monsta...
They also sent some stuff for review in the pump roundup:
This is a single bay res with dual pumps:
It takes these tiny DC-LT pumps from alphacool also, they're not included with the res:
But they sent me some too:
Box not up to the usual alphacool standard:
Tiny DC-LT pumps, we'll have to see what they can do:
No kidding they sent me more stuff for review:
Well we know it's a pump/res of some kind:
It's a 2 bay res that can mount 2 D5s. It's a similar setup to the RP452x2 that I have:
Alphacool's black/copper theme is very consistent:
This one won't go in the build:
But it did come with 2 D5's which I may end up using to replace the DDC or Iwaki:
Alphacool's VPP655 is just a bare D5 vario with tach wire:
Spotswood had also sent me an update for the tech bench after I had some feedback for him:
A new "open" top tray:
Taller posts so that the PSU can be mounted vertically, enabling a 2nd PSU to be fitted:
And a HDD rack:
This is the old one:
Getting taken apart:
Now with more rotation:
I tried the HDD rack at the back:
(I have the case rotated on my bench so that the back is easily accessible). The HDDs slide in on rubber grommets:
Adding the new top:
With boards and gpu:
Nearly done:
In the end I moved the HDDs to the front and mounted the crystalfontz data logger in the back:
This gives me space to get my hands under the motherboard for fitting backplates. I tried mounting a 360 to the side, but had to offset it a little for easy tube routing:
Now you can see the datalogger next to the PSU:
You can also see the GT that I mounted on a sliding arm under the CPU. This cools the VRM's on the back of the board that will cause CPU throttling if they over heat. The sliding makes it easy to move out the way if needed:
Move views:
I'll be using this just for controlling PWM in the upcoming pump testing lol. Talk about overkill. I have a couple of new cpu blocks to test though and then a titan waterblock roundup to do afterwards so it'll be more useful for that:
The schmexies:
Close up of how Spotswood builds up the frame from all the extrusion pieces:
That's it for now!
HammerON
8,397 (1.52/day)
Up North
Processor 3960X
Wow - nice update and pics:toast:
That is a lot of new toys to play with:)
777 (0.18/day)
Norway
System Name Games/internet/usage
Processor I7 5820k 4.2 Ghz
Motherboard ASUS X99-A2
Cooling custom water loop for cpu and gpu
Memory 16GiB Crucial Ballistix Sport 2666 MHz
Video Card(s) Radeon Rx 6800 XT
Storage Samsung XP941 500 GB + 1 TB SSD
Display(s) Dell 3008WFP
Case Caselabs Magnum M8
Audio Device(s) Shiit Modi 2 Uber -> Matrix m-stage -> HD650
Power Supply beQuiet dark power pro 1200W
Mouse Logitech MX518
Keyboard Corsair K95 RGB
Those arctic cooling 120 mm pwm fans are rely good. Have 24 on my computer and the loudest component is either a MPC 35X or the to Samsung 5400 rpm drives in it.
This seams like a never ending build, filled with dream parts.
de.das.dude
Pro Indian Modder
8,756 (1.74/day)
VR HMD ;_;
thats... a big upload.
211 (0.05/day)
Yes yes it is!
Yes the quietest fans I've heard when turned down. At full speed they're noisy given the air they push, but that's not why you buy them.
211 (0.05/day)
Been a while, so here's kind of a dump of what I'vee been up to.
LIES:
Also
Also
So the 9500GT in mini thief died last night, thinking about swapping out my 8800GT from the project thief workstation into that rig and getting a low end kepler for the workstation can drive three screens. The workstation uses linux and I'm thinking to switch my U3011 for 3 1080p lightboost monitors in portrait. When I've run multiple screens across multiple GPUs in linux before with Xinerama then X gets a bit laggy, so this would help with that as twinview on a single card works great, and I've read that twinview can have three screens with Kepler. The cheapest kepler with a block would be a 650 ti boost, but the block is a CSQ while the rest of the workstation uses non-csq blocks. Any thoughts? I'm reluctant to try AMD for a workstation GPU because even with nouveau drivers my tools become way more laggy than the official nvidia drivers.
I'm also debating paint and fittings for the 990x/R3E motherboard/RAM loop on the gaming rig. The idea is that the workstation half would be "white" (e.g. white blocks, dt sniper white, EK white D5 top, EK white reservoir, nickel/plexi memory block and copper/plexi gpu painted white and maybe even the motherboard nickel plexi block painted white too). The gaming rig would be the "dark side" acetal cpu and gpu blocks (although I just sold the GPUs). However the motherboard is nickel/plexi and the ram block is copper/plexi (not shown here):
Originally I thought to paint these black, but then you won't even see the dye in that loop. So I was thinking maybe a black chrome finish instead just for the memory block? I could paint the motherboard block stainless steel cover plate in the middle of that block black to fit the theme. Should I then use black chrome fittings or just straight black? Also that 120 radiator is getting swapped for a black one and that fan is getting swapped for a black/red fan. Also those QDCs will be hidden away.
So to summarize I want your thoughts on these questions:
Stick with light/dark theme?
Workstation
Paint the metal parts of the workstation plexi blocks white?
Use 2x8800GTs and suck up any lag if present or switch to a 650 Ti Boost with a CSQ block?
Stick with the plan for white fittings?
Use a silver painted radiator with a silver/red fan?
Gaming Rig
Paint the RAM block black or black chrome to hide dat copper?
Paint the Motherboard block fully or only the cover plate and if so black or black chrome?
Use black fittings or black chrome?
End of questions - did this any of this make sense?
Current hardware plan (very subject to change) is to eventually add two titans or titan LEs and if I upgrade the workstation to the 4930K then the gaming rig will get the 3930K from the workstation and an X79 Dark board :thumb:
Also random shot from the mini-thief build - one thing i love about the M5Gene board is that glowing LED strip they put into the board - super cool:
I'd love to see them do something similar on a real R4E BE board not that promotional 3 board run crap they did ;)
I upgraded the bios to avoid throttling and increased the power limit of the card so that I could try and seperate the results from the error as much as possible. I'm running Naennon's 145% Max Power bios. My max clocks were around 1150-1175 @1.212V (not the best card), so I downclocked to 1123MHz and tried a few benchmarks/stress tests to see what power levels I could get. Furmark was giving me a nice solid 120% level so I decided to go with that. I'm logging card temps with precision-x and the water/ambient temps with WinTest. I took some baseline measurements on air, with the fan at max (85%) the card was running about 50C over ambient which is not bad at all even if the fan is super noisy. First block on the testing rig is EK:
I also had time to unbox the hydrocopper card. The packaging is much less fancy than the Titan:
The only block to include the metal bracket to go around the gpu processor.
Accessories:
2 Pairs of compressions and 2 stop fittings:
The matt block contrasts with the shine of the EVGA sticker:
I feel like the sticker takes away from the classyness. I would have preferred it to be cut out of the plastic just like the swiftech logo is:
Maybe even make it consistent with the style of the top and maybe even light up some text there too:
The base is nickel plated:
And it's kind of nice that they preattach the thermal pads for you:
Had the hydrocopper on the testing bench. Results can be found on the interwebz.
Also spent the whole of saturday running flow/restriction curves on 17 waterblocks :rolleyes:
I'd planned to disassemble the TX10 today because I'd found that if you rely on your rig that you're currently building for your day job and need a high percentage of uptime on that same rig, then it becomes very hard to get anything done. So I'd planning to run a bench setup for a while until I finish Thief. However on saturday just before I was about to process the restriction curves, my D5 on the motherboard loop started making horrible noises. I shut down the rig, but my gaming rig still wasn't functioning as the PSU died last week and the warranty replacement wasn't here yet. So it was time to strip them both out and make a frankenstein rig out of working parts. Hopefully parts that I wouldn't use in the final thief build. So here's the dissasembling which was very quick due to the TX10 design (quick release side mounts and motherboard trays FTW) as well as many QDCs. Photos aren't that great because I wasn't spending time to setup the tripod. I needed my workstation running for monday morning. I used the "bench mount" kit for the CL tray and used an old fan cut into a shroud to mount the radiator to the back of the tray. To support the weight of the rad on the far end I also have a piece of wood lulz
Yuck dust!
Parts:
Draining the windows rig - this will become the linux workstation temporarily, I was rolling with the old 460 after selling my 580s and before the titan/780 transition:
Stripping
Nearly naked:
I painted this RX360 for the build before I decided to change to a light/dark theme and before I got sponsored by alphacool:
Still rocking the sniper:
And of course EK still sponsor many other parts:
Now if only ROG would sponsor me too :rolleyes:
I love nickel plexi
Luckily Corsair does sponsor me too, I love GTs, who wants anything else:
And I still choose GTs over platinums because I love those red tops. And they're waterblock compatible. You know if I ever get around to that....
Decided to run the monsoon lightports. I might switch to the carbon fiber ones though in the final build:
And it's about time to use some of that dye:
Ready to fill up:
XSPC don't sponsor so this one's a freebie :rolleyes:
Get that dye in there!
Masterkleer tubing hooked up, I was out of primochill clear so I was going to use this up, already turning a bit yellow after 6months of sitting in a dark box :/ :
Forgot to tighten that middle compression, luckily it didn't leak:
sexy:
fill her up:
Leak testing:
No leaks:
Yummy:
I WANT TO EAT IT
NICKEL PLEXI AND DYE IS SO SCHMEXY
Done with the overnight leak testing and setting up:
Added an LED to the pump top:
Light ports are weak during the day, hopefully I'll get some dark shots later on:
I rotated the tray onto a spare desk and sat the PSU and HDD cage on the desk too. I put the PSU on some bubble wrap because it was having some weird resonance with the desk:
I kinda wish I had a 2nd spotswood tech bench to be honest, but this'll have to do, the "tech bench" feet that CL have for it work well and I can afford the desk space for the rest of it.
So the extension wasn't supposed to have this much bend so the inner wires are pushing through the outer :(
Stripping down the old R4E, the nickel is stained because I ran pure distilled without a corrosion inhibitant...
I do prefer this to csq though
beautiful condition one mount only :)
One mint always under water combo
Say farewell to these:
Got the hydrocopper block tested (results on the website)
Got a new lens :)
Dust:
Mo' Dust:
Replacement NEX1500 PSU came in to replace the dead one:
I wish I had two of these beauties:
Oh wait I do, well temporarily:
Also got a GPU in for the workstation, now I can do three monitors with one card. Can you guess:
This one gives it away a bit:
The nice thing is that the 650 ti boost with the blower cooler like this still is compatible with a 600 block.
So as part of the "getting stuff done" theme, I'd moved thief downstairs to the garage and setup the temporary test bench. The garage was still a mess as I was waiting for new benches and shelving units to come in so I could actually do something.
I also forgot to bring home my liquid tape from work to add in the bazillion new thermal probes I got so titan testing was on hold:
However I could continue some of the sleeving work:
I'd previously done one 24 pin, an 8 pin and a 6 pin. Since then Lutro0 had sent me some shiny tools and I'd started working on another 24 pin extension. I wasn't happy with the length of the inner run though as it wasn't giving me enough curvature, so I removed those wires leaving me only the outer layer:
I used lutro0's 16 AWG wire, which is pretty easy for a relative nub like me. By the end I was wishing for something stiffer though, but combined with the MDPC-X sleeve the resultant extension is pretty stiff. It still needs a good amount of training, so I seperated the two layers with some thin plywood:
and clamped it in position:
The look is just about perfect, and hopefully it'll hold after a bit of time sitting like that:
I'd also seen some staining on my nickel blocks which looked similar to EK's testing of distilled only with no anti-corrosion additive:
The acrylic isn't stained of course, but it's good to check:
Giving the block a good scrub with detergent did nothing.
EK used a metal polish to clean their blocks up and couldn't get it out of every recess, but I'm lazier than that and wanted better results so I did some research. Most people say don't use ketchup because you'll eat through the plating. So I thought I would try it on the underside to see how long it takes:
After one hour:
The dark marks were not there before, the underside was actually clean. Not sure if the dark marks are staining or where the acid etched through the nickel faster. I'm going to continue the experiment to see how long it takes...
So that's it for now, hopefully future updates will be more frequent!
211 (0.05/day)
Alright time for a massive update - I hadn't been updating this thread in a while, but here's all my updates from the last 6 months because I am done!
A box
That shipped remarkably quickly, it got here last night, and I didn't notice, so it sat there all night long:
Christmas morning. 8 Rads:
Stack those rads, rads love to be stacked:
Now lets add the other ones I already had cause they wanna be stacked too:
MORA wants in, but it needs to be stripped:
Nice and nekkid and clean:
211 (0.05/day)
This is what's going in thief:
This is the rest of the hoard excluding 2 560s, 3 360s and a 120 lulz:
Playing around:
That's it for now...
211 (0.05/day)
I did buy some more fans and did some other background work ;) This is now my total stash of gentle typhoons (excluding a couple in my benching setup):
9 for the Mora 140x9 (Push only)
16 for the 2 560s
24 for the 4 360s
The two 120 rads will get non GTs because I want something cooler looking for the chamber.
So thief will get 49 of these, I have 60 because I wanted 8 for the 2x240s for the S3 and then a few spare in case of deaths. Of course maybe I'll change my mind and run P/P on the mora or add in another 360 just because a total of 60 fans in the build is pretty lulztastic.
Bought some wood for it, got a 1" piece and had the guys resaw it in two and finish it down to about the right size. With finish and a bit of UV aging it will get a good bit darker too. The colors should be beautiful...
Well only one terabyte of ssd would have been too little:
No more loneliness, two of everything!
211 (0.05/day)
So for a while there I was going to run the impact and a 290 on one side as a gaming rig. Just for trollsies. Would have been pretty funny to have 4x360s for one 290 and and 2x560s for one 4770K. Also that huge motherboard chamber with mitx would have been a bit of a giggle. But I got a bit more real and bought some other stuff. The Impact is currently running on the testbench testing blocks. 4770K block testing is done and it's now onto the 290 block round up version 2. In the mean while I did stuff on thief - some of you might remember me posting something about wood and then buying a panel that was then cut down the middle:
So it was time to mock up some designs on card:
This one I liked, but I wasn't sure which parts to do in wood and which parts to do cut out and then how to join the floating bits. So I tried something more minimalist:
Then mocked them up with PS:
minimal:
nightingale + dragon:
I was worried that this was too detailed and that the dragons were cheesey. I also considered adding the skyrim dragon logo on to the minimalist version:
I also considered writing project thief in dragon letters:
In the end I settled on the original minimal design:
211 (0.05/day)
First job was sanding the surface smooth as it had already been planed flat:
And then cutting to size:
The idea was to recess behind the front panel, as I dont' have a router I needed to make sure I could do it with my table saw by making multiple cuts. Here's one:
and many:
side profile:
The test fit perfectly:
Next up the whole panel:
211 (0.05/day)
and the second panel:
I then cut out the card to use as a stencil:
And started marking out:
Drilled holes to start the jigsaw cuts:
More holes:
And the first jigsaw cut:
Cleaned it up with some chisel work:
Oh and the recessed cuts needed cleaning up too:
Did some more cuts and decided to bevel the edges:
211 (0.05/day)
After two had gone well I was ready to start the rest, I thickened up the marking to the edge of the cut - originally the line to cut was done in pencil with an additional sharpie line close by to let me know approx where I should be, but it was hard to see the pencil with the dust:
Progress:
More progress:
Test fit:
After some finishing sanding and clean up:
I also started to recess the sections that connected the "floating" parts of the symbols:
Time for dat second panel:
Oh that was fast:
Normally I like to use natural shellac finishes for this kind of wood, but given the heat variation I wanted something that might seal the wood a little better so I decided to try a clear polyurethane:
211 (0.05/day)
Sadly the wood is so oily that the poly doesn't really dry, and I had to scrub the wood down with rags and mineral spirits to clean the oil off and let the finish dry. It was a real PITA and I wouldn't do it again lol. They came out well though:
So now that that was done it was time to get the hardware sorted. Monsoon sent a care package of stop plugs to replace the ugly alphacool copper ones:
Not sure if I showed this before or not, but if so then tough cookies:
I'd also been busy prepping and sleeving fans for the rads:
Product placement:
The problem with the alphacool rads (or the rad mounts) is that the stop fittings stick up and hit the rad mount. You need to use some kind of spacer. This is the phobya 7mm version:
Progress:
211 (0.05/day)
It was also time to upgrade/replace hardware - that 3930K died so I RMA'd and while I waited bought a 4930K:
I then sold the RMA part and shortly after decided to buy a 4820K:
Of course I needed a board to run the 4820K in, having bad experiences with Asus's RMA program and tech support snarky snarks I decided to give the new evga board a try as it was alleged to be a bazillion times better than their older x79 boards:
Dat sexy:
Now I know some of you are like me and were like "but you can't get blocks" well natemandoo solved that as we'll see later. My original plan was to use a 120 rad mounted to the tray to do a motherboard/ram only loop:
I knew this was silly, but it was only when I was looking at my pumps and knew that although I had 5 D5's for this build that I'd still need 2 more that I realized, maybe I should just not do that lol. There was a time where I wanted to have everything at max performance, but at some point if you really want the best temps you may as well just go sub ambient. So let's pretend that 120 will go away. Meanwhile I added RAM:
211 (0.05/day)
Added the CPU:
Closed the top:
Later found out these were the RAM slots, but in the meantime auditioned some CPU blocks to see what looked best. The Sniper was a bit too small to cover the metal of the socket:
The MIPS is a great block but didn't really suit the theme:
The 5Noz covered more than the sniper, but not enough:
The DD M6 provided a nice contrast with it's nickel, but this helped cement that I actually wanted something large and black:
Which led to the surprise winner:
I setup a temporary loop in order to have something while I debugged the GPUs on air:
211 (0.05/day)
So speaking of GPUs - oh yes I bought some of those:
A couple of 290s, then a couple of 7970s:
Then a couple more 290s:
Then a pair of 7990s:
Yes things were getting out of control:
It was clearly time to make sure they worked - starting with a 290:
Then adding more:
And more:
211 (0.05/day)
So there's a bunch of parts coming in:
- Care package from Monsoon
- Package from PPCS
- A bunch of EK parts
The final build will be
- R4E + 4930K + 2x7990 + AX1200 + 1TB 840 EVO + 8*4GB 2133 Dominator CL9
- X79 Dark + 4820K + 4xR9-290 + NEX1500 + 1TB 840 EVO + 4*4GB 2133 Dominator CL9
All GPUs, CPUs and Motherboards will be watercooled, the 8 way dominators will be water cooled also.
The 4x290s will be cooled by 4x UT60 360 rads
The 2x7990s will be cooled by Mora 9x140
The 4930K will be cooled by a Monsta 560
The 4820K will be cooled by a XT45 560
All radiator fans will be AP15s/AP16s. There was a plan for a while to mount 3 Aquaeros in the pedestal to control the fans, but as this will be mining there's not much point right now. We'll see if I ever want to rebuild down the road and add them lol.
The only remaining thing I need now is the mandrel kit from Monsoon which is OOS everywhere. So I'm finally ready to build. There's a ton of extensions to be made and a ton of building and bending to be done, but the good news is that after 2 years things are finally moving and the end is in sight :thumb:
Another care package from the lovely Monsoon team via PPCs :D
Oh yeah you know what we're up to:
Dat chrome:
The monsoon hardline fittings actually have you glue a sleeve to the tube. The lock ring then presses this collar up to an o-ring for an ultra secure seal :thumb:
More boxes:
All the new toys:
It's not all hardline:
Hardlining only the main chamber, the rest gets tube because the case is just too big.
211 (0.05/day)
Dem blocks:
More blocks:
Backplates (I already had another two):
Res tubes:
More QDCs because I have to have spent more on QDCs than CPUs or else this build would be normal.
Dem accessories:
Dem fittings again:
Let's open things up:
211 (0.05/day)
Wait for it
Oh yeahhhhhhh
Well one of the 290 blocks was gently used, can you tell?
Now we have all this stuff then it might be time to do something then:
Pumps - check!
Reservoirs - damnit forgot to order a replacement top... Ok so let's fit a block instead on a 7990 as this is the only card not being used right now:
Taking off dat backplate:
Dirty and naked:
