project water cooling in antec 600 part 1
Discussion in 'Project Logs' started by DTV DRAGON, Jun 4, 2010.
  1. DTV DRAGON
    DTV DRAGON New Member
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    ok guys i finaly started today on setting up my water cooling system in my antec 600. For the first part of this build I will not be doing any painting on the case itself. This will only be the modding and fab part, and after I have that completed and ran for awhile, I will then yank it apart to paint the inside of the case etc.This will be done at a snails pace because of my pain condition, so if it looks like Iam not makeing much progress please keep that in mind.So today it was bascial just cutting away on the harddrve cage as well the cable managment panel so i can fit me rad upfront,I was thinking about mounting it uptop, but with it upfront i can still use the two 120mm fans that are stock on my 600 to pull in cool air,and then i mounted another set of 120mm on the rad so I have a push/pull air effect happining.with the front panel back on you cannot even tell that there is a rad tucked in behind there,So at this point I have the rad mounted and secured in place. and then found a nice spot for the reservoir (bought from sniperbob), but needed a way to fill it once it was mounted,so only thing i could come up with was plumbing some of my 1/2 red hose (that I bought from jellyrole) from the top of the res going through the top of my case (still need to make some sort of kewl looking cap for it) and that was about it for today as i needed to put it back together as its our only puter in the house lol, Part 2 will be mounting Swiftech MCP655 pump/EK-FC5870 for hd5870/laying out hose routeing
  2. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    well did abit more work today, and actually running on water as i type, I did not change over my 5870 yet as i wasnt feeling to great today , so i just attempted to get it to where it is now, I will run it for a few days like this and then start the second last part of this changeover Needless to say I was nervous as hell looking for any leaks or water dripping lol. but there was none. I have not run any temp benches yet, but in core temp it is idleing at 36 oc/ed to 4.1, cant wait till i have the 5870 in the loop as well, here are a few pics of todays work, also bought that neat little lcd graph temp gauge from fleebay, and drilled a hole and slid her down into the rez to give me a readout on my water temps, I mounted the gauge upfront on the case bezel.I will take some pics of that working and post them later on
  3. mav2000
    mav2000 New Member
    Nov 26, 2008
    451 (0.17/day)
    53
    Bangalore, India
    Would like to see how you mounted that read out there...nice work.
  4. (FIH) The Don
    (FIH) The Don
    Aug 11, 2009
    6,823 (2.87/day)
    2,910
    Viking Land
    maybe cut a hole under the psu and flip it? will help you with wm imo
  5. jellyrole
    jellyrole
    May 11, 2009
    1,022 (0.41/day)
    212
    Manhattan
    That tubing looks familiar.
  6. MT Alex
    MT Alex
    Aug 2, 2009
    3,979 (1.67/day)
    1,789
    Nice looking build. It's always a nail biter when you first fire up your loop. I moved to water just after Christmas and I'm still happy everyday after work when I find my computer hasn't leaked:) I'll never go back to air. Also, I like your red rad fans, they go well with the 5870. I was a little disappointed when I put the block on mine and lost the batmobile look.
    DTV DRAGON says thanks.
  7. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    yeah works great with my red theme, Also iam going to filp the psu so the wires are more to the inside of the case, wich will make it alot cleaner, Tommorow if iam up to it i will start the last phase and get the 5870 in water as well., thanx for commets guys
  8. brandonwh64
    brandonwh64 Addicted to Bacon and StarCrunches!!!
    Sep 6, 2009
    19,227 (8.19/day)
    6,679
    Chatsworth, GA
    Nice dragon! its nice to see you got to 4Ghz on the CPU!! i remember when you first started OCing it and we were PMing up a storm!
    Crunching for Team TPU
  9. Loosenut
    Loosenut
    Jan 14, 2010
    896 (0.40/day)
    205
    Granby, Qc. Canada
    Nice job man :toast:
    Is it me or is your inlet/outlet on your cpu block backwards? :confused:
  10. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    nop you caught me..good eye lol its changed already. I was wondering whp would get that, also here is a pic of my lcd meter that reads the water temp in res, I still need to fit the trim ring on so it covers the gap i have on one side
  11. Loosenut
    Loosenut
    Jan 14, 2010
    896 (0.40/day)
    205
    Granby, Qc. Canada
    :p
    Lolll, I have the same temp meter... :roll:
    EDIT: Temporary setup :eek:
  12. brandonwh64
    Sep 6, 2009
    19,227 (8.19/day)
    6,679
    Chatsworth, GA
    Were do you guys get that meter?
  13. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    brandon i got minr from fleebay, came from hongkong, but got here very fast,seems like stuff from hong kong gets here faster than when i order from the us, it actualy works very well. drilled a little hole in my res and inserted the probe and done deal,also today i will be doing the 5870 convert over, stay tuned for pics and results
  14. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    ok here is the 5870 changeover process, It all went very smooth,and i would say putting a water block on a gpu is a 3 out of 10 on the difficulty scale
  15. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    here are some pics of the 5870 completed with chrome backplate installed as well
  16. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    and some more pics of it getting put into case
  17. kenkickr
    kenkickr
    Dec 5, 2007
    4,949 (1.66/day)
    1,664
    Those EK blocks look sexy and also perform wonderfully. Lookin good so far.
  18. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    and now for a pic of the temps i get now with the 5870 on water.when it was on its stock cooler my temp was 50-52 at idle, (card o/c'ed to 975@1300 @1.25v) all I can say now is WOW what a difference water makes on the gpu!!
  19. Loosenut
    Loosenut
    Jan 14, 2010
    896 (0.40/day)
    205
    Granby, Qc. Canada
    I couldn't agree more Dragon. :toast:
    Excellent choice for GPU block ;)
  20. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    loosenut,....you more than anyone would know that!!!!! I made a good friend from some compresion fittings and a ek gpu block :)
    Loosenut says thanks.
  21. kenkickr
    kenkickr
    Dec 5, 2007
    4,949 (1.66/day)
    1,664
    Nice temps. I run mine @ 1Ghz GPU/1.3Ghz mem on 1.125v without issues. I've recently played around some more and it takes 1.35v to run 1150Mhz GPU/1350Mhz Mem. Still sitting under 50 celcius at full load.
  22. Loosenut
    Loosenut
    Jan 14, 2010
    896 (0.40/day)
    205
    Granby, Qc. Canada
    :laugh: Interesting story too... Maybe you should share it, I do believe it pertains to this build, wouldn't you say?
    Good job Bro, looks sweet so far :toast:
  23. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    sure does! and as soon as i come back from doc appt. i will :)
  24. Loosenut
    Loosenut
    Jan 14, 2010
    896 (0.40/day)
    205
    Granby, Qc. Canada
    Hope all goes well Dragon, we're prayin' for ya :)
  25. DTV DRAGON
    Jun 3, 2008
    877 (0.31/day)
    64
    canada
    hey guys, thought id posta quick pic of my temps under full fur mark load, have to say that before water my temps were at 72 and now they are at 45 and at even higher clocks
    my clocks are now 1018@1306 and 1.287 volts, and i know i can go alot higher or at least until it starts to drop in performance, wich i couldnt do on air before, I will post more later on as i need to take a rest now, wasnt a great doc visit as some of you kinda know what is going on with me take care
