Project WaterFall -- A water cooling project log by Phenom
Discussion in 'Project Logs' started by MxPhenom 216, Oct 16, 2012.
  1. MT Alex
    MT Alex
    Aug 2, 2009
    4,014 (1.34/day)
    1,857
    Enough talk, put it together already.
    Sir B. Fannybottom and erocker say thanks.
  2. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    12,105 (4.64/day)
    3,713
    Seattle, WA
    Working on it right now. Just took the cooler off the GPU.
  3. manofthem
    manofthem WCG-TPU Team All-Star!
    Jan 9, 2011
    10,671 (4.31/day)
    25,857
    Florida
    That's a sexy sight, isn't it? Take some nice ones of that!
    Crunching for Team TPU
  4. MxPhenom 216
    Aug 31, 2010
    12,105 (4.64/day)
    3,713
    Seattle, WA
    yeah if i wasn't so shakey!
    Jesus, Evga cooler sucks! They don't even have contact points for the VRMs and memory. My card is going to love this water! The VRMs and memory will actually run cool haha!
  5. Wrigleyvillain
    Wrigleyvillain PTFO or GTFO
    Oct 13, 2007
    7,693 (2.10/day)
    1,788
    Chicago
    Oh, so you know dude, you will of course be careful as all hell but will nonetheless, at some point, get some water on your GPU or mobo and/or inside your case. Hopefully nowhere critical while powered on but, in general, it happens, so just don't freak out (like I did the first time) and dry everything off and just be patient overall and all will be just fine.
    10 Year Member at TPU
  6. MT Alex
    MT Alex
    Aug 2, 2009
    4,014 (1.34/day)
    1,857
    You still working on this?
  7. MxPhenom 216
    Aug 31, 2010
    12,105 (4.64/day)
    3,713
    Seattle, WA
    Yeah I didn't finish today and probably won't tomorrow.
  8. MxPhenom 216
    Aug 31, 2010
    12,105 (4.64/day)
    3,713
    Seattle, WA
  9. ChaoticG8R
    Nov 9, 2011
    396 (0.18/day)
    244
    And people thought my build was slow...I went from nothing to completely built...you are just doing a GPU loop :nutkick:
    MT Alex says thanks.
  10. MxPhenom 216
    Aug 31, 2010
    12,105 (4.64/day)
    3,713
    Seattle, WA
    Oh shut up. Im not in a rush to get it done. I have other stuff going on.
    ChaoticG8R says thanks.
  11. MxPhenom 216
    Aug 31, 2010
    12,105 (4.64/day)
    3,713
    Seattle, WA
    Pictures from the work done yesterday.
    I really need to get a nice SLR camera
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [H]@RD5TUFF, MT Alex and manofthem say thanks.
  12. manofthem
    Jan 9, 2011
    10,671 (4.31/day)
    25,857
    Florida
    Ok we're making progress and it's looking good! I can see that you've got quite a few things going on there :eek:
  13. MT Alex
    MT Alex
    Aug 2, 2009
    4,014 (1.34/day)
    1,857
    This shot turned out really nice.
    In my experience, GPUs need the spread method as opposed to the blob. Looks like you have about 40 minutes of work left, so you should be done by Election Day.
    Sir B. Fannybottom says thanks.
  14. Wrigleyvillain
    Oct 13, 2007
    7,693 (2.10/day)
    1,788
    Chicago
    Looking good indeed.
  15. MxPhenom 216
    Aug 31, 2010
    12,105 (4.64/day)
    3,713
    Seattle, WA
    Ill probably be done by wednesday night this coming week.
    I just got the GPU connected with one line of tubing. Just got to mount the res/pump and connect the lines. Hardest part will be to give it enough slack in the tubing to be able to pull it out to fill.
    For testing leaks for the res/pump can i just put normal water into it and then just empy it out and let dry once and can confirm their are no leaks?
  16. manofthem
    Jan 9, 2011
    10,671 (4.31/day)
    25,857
    Florida
    I wouldn't want any residue left in the loop. It likely won't take much water at all to fill your entire loop, so I wouldn't worry about waste.
  17. MT Alex
    MT Alex
    Aug 2, 2009
    4,014 (1.34/day)
    1,857
    You can get a gallon of distilled water nearly anywhere for a couple of bucks, I'm not sure why you'd want to fill and bleed it twice. Fill it, leak test, done.
  18. Nordic
    Nordic
    Jun 27, 2011
    5,623 (2.44/day)
    2,990
    Distilled water where I am is 99 cents per gallon. Couldn't be that far off in seattle.
    What is that powercolor thingy you mentioned above. It is meant to prevent the card from bending or something. It did not have a very good description and many of the reviews speak as if it was gpu.
  19. MxPhenom 216
    Aug 31, 2010
    12,105 (4.64/day)
    3,713
    Seattle, WA
    No no, Im talking about just in the res/pump. Not the whole loop.
    Its a graphics card jack to prop it up so it won't sag. I was thinking about getting one for now till i get the back plate
    Nordic says thanks.
  20. MT Alex
    MT Alex
    Aug 2, 2009
    4,014 (1.34/day)
    1,857
    If you're that nervous about it, sure. It's not a Steinway.
  21. Nordic
    Nordic
    Jun 27, 2011
    5,623 (2.44/day)
    2,990
    I plan on getting a backplate for my 7970. Dwood on OCN makes custom back plates for $20ish and I was thinking about getting one of those and some thermal pads. The backplate for rigidness and the thermal pads because they can't hurt.
  22. HammerON
    HammerON The Watchful Moderator Staff Member
    Mar 2, 2009
    7,406 (2.35/day)
    4,714
    Up North
    You should leak test the whole loop. Just leave the 24-pin unplugged from the motherboard and short the 24-pin to start the PSU. This will allow you to leak test and not have to worry about shorting your system out:)
    Do not use regular water from the tap! As others have stated, distilled water is cheap and should be used.
  23. MxPhenom 216
    Aug 31, 2010
    12,105 (4.64/day)
    3,713
    Seattle, WA
    Should I be worried about how much my card flexes? Or is this a pretty normal thing when putting a waterblock on a video card?
  24. t_ski
    t_ski Former Staff
    Apr 11, 2006
    11,960 (2.84/day)
    6,525
    Flexes as in dips down at an angle, or flexes as is bends in the middle? Sagging is normal due to the increased weight, but bending in the middle is bad, possibly due to incorrect mounting pressure or incorrect mounting.
    10 Year Member at TPU Crunching for Team TPU
  25. MxPhenom 216
    Aug 31, 2010
    12,105 (4.64/day)
    3,713
    Seattle, WA
    This is what it looks like. The card before would bend slightly from the middle because of the EVGA shitty cooler that only had 4 screws around the GPU and none to the GPU I/O backplate etc so it would just pull it down from the middle. And I think the PCB has kind of just taken that form from getting hot and sagging because of it. But take a look at this picture, as thats what it looks like currently
    [​IMG]
    Other then that. Ive decided to complete all the system cabling now before getting the res/pump all connected so that none of it is in the way. Just got to connect fan cabling and DVD drive.
