PSU fan most noisy fan in my system
Discussion in 'Overclocking & Cooling' started by P4-630, Jul 3, 2008.
  1. P4-630
    P4-630
    Jan 5, 2006
    1,583 (0.47/day)
    257
    Los Santos
    About 2 months ago I bought an Enermax Liberty 400 power supply, it's a great power supply and overall quiet, but the fan in this power supply is making the most noise of all, that 12cm built-in ball bearring spins at 1000-1300rpm during the day, ok it is not that very noisy, but its said that it makes the most noise of all in my system!
    I gave it a try and replaced the original fan with a cooler master blue led fan about a week ago but it did not work, I had to cut and re-attach the wires to the 3pin connector for this.
    The blue led was on but the fan did not spin at all!:(
    Does anyone know which other 12cm fan works with an enermax psu?
    Thanks.
  2. SerenadeRB
    SerenadeRB New Member
    Jun 30, 2008
    183 (0.07/day)
    33
    Whitestone, NY
    Have you tried lowering the rpm? I do believe that it has a variable speed control ( iirc). Also the best way [imo] to ensure compatibility is to use something by the same manufacturer. If you like silent than this Enermax fan runs at 17dBA, very silent.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811999099
    Plus it's inexpensive so it shouldn't dent your pocket like some $40 fans i've seen =]
  3. oli_ramsay
    oli_ramsay
    Sep 22, 2007
    3,480 (1.25/day)
    569
    UK
    You could use a fan header on your motherboard to power the blue LED fan you bought for your PSU.
Share This Page
