- May 14, 2010
- 901 (0.18/day)
- NYU
System Name | Baby Box |
Processor | i5 4670K @ 4GHz |
Motherboard | Asus Z97I-PLUS |
Cooling | Corsair H100i |
Memory | 16GB Kingston HyperX FURY DDR3 1600MHz @ CL10 |
Video Card(s) | EVGA GTX 780 Dual FTW w/ EVGA ACX Cooler |
Storage | Crucial M500 240GB SSD (Boot Drive); Seagate 7200.12 1TB 7200RPM (Storage) |
Display(s) | ASUS VH222H 21.5" 1920x1080 |
Case | Corsair 250D Mini ITX |
Audio Device(s) | Audioengine D1 DAC/Amp |
Power Supply | Cooler Master GX RS750 PSU |
Mouse | Corsair SCIMITAR RGB |
Keyboard | Corsair Vengeance K70 RGB |
Software | Windows 10 Pro x64/ Linux Mint 17.3 |
Well according to FrozenCPU "While designed to be corrosion resistant, OCZ reccommends the use of integrated anti-corrosive additives for all water cooling systems to ensure maximum lifespan of your products." So it is recommended to use glycol. However if you notice any micro cracks starting in your res then I would swap the res out or get a better pump like the MCP 655 or something. May want to include a drain as well in your next tube routing project. Makes it easier to empty the loop and clean the system from time to time.
Yeah, there are some micro cracks starting to show on the left side. How much to MCP 655's go for?
EDIT: That's without added glycol, is that bad?
