PWM LED 92mm Fan
Discussion in 'Overclocking & Cooling' started by aximbigfan, Jun 19, 2009.
  1. aximbigfan New Member
    Oct 15, 2006
    848 (0.27/day)
    35
    St. Louis, MO
    Anyone know of a good (and Blue) PWM LED 92mm Fan?
    I found the Sythe Kama, but I can't find a place in the US to buy it.
    Thanks!
  2. Wrigleyvillain
    Wrigleyvillain PTFO or GTFO
    Oct 13, 2007
    7,684 (2.72/day)
    1,780
    Chicago
    Thermaltake makes a blue 92mm. The side intake on the Tsunami and probably a few others is that size. Wouldn't recommend their products usually but seemed to move a good amount of air. Not sure if PWM tho, can check at home.
    Maybe can find one here as well:
    http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=68
    Looked closer and the TT I mentioned is on that page above. The call it a "smart fan" has a temp sensor and a manual control.
    http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=68&products_id=1143
    Sell you mine for $11 shipped btw.
Share This Page
