Question about fan speed
Discussion in 'GPU-Z' started by Derek12, May 16, 2012.
  1. Derek12
    Jan 12, 2010
    1,115 (0.50/day)
    164
    I see in some GPU-Z shots the fan speed is given in RPM, besides the percentage, but here is only the percentage value that does not reflect the real fan speed as I stop it and it is the same, is there a way to make it show as RPM values or is that a hardware measure?
    Many thanks
  2. redeye
    redeye
    Dec 24, 2010
    249 (0.13/day)
    44
    mississauga, on, Canada
    compare the readings from gpu-z to speedfan, and/or the MB(graphics card driver) utilities to determine where the fault lies
  3. Maban
    Maban
    Mar 6, 2008
    2,674 (0.92/day)
    1,265
    Minnesota, Canadian States of Norway
    Your card's fan simply does not have any way to measure RPM. If you look at your card, you'll most likely see that it only has two wires going to the fan, power and ground. Without a tach wire, it cannot read RPM.
    Derek12 says thanks.
  4. Derek12
    Jan 12, 2010
    1,115 (0.50/day)
    164
    Many thanks, I thought that if it could change the speed with only two wires, maybe it could read it somewhere :)
    redeye, all programs (hwinfo, GPUZ, AIDA64, speedfan state 40% must be OK :)
