rampage formula problems or hd4870 problems...
Discussion in 'General Hardware' started by ashwinc, Feb 13, 2009.
  1. ashwinc New Member
    Feb 12, 2009
    12 (0.01/day)
    0
    london
    ASUS Rampage Formula Republic of Gamers Series iX48 lastest bios 701
    Core 2 Duo E8400 Socket 775 (3.0GHz
    Corsair 4GB Kit (2x2GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Sapphire HD 4870 1GB
    Corsair 620W HX Modular PS
    1TB Hard Drive SATA300 7200rpm 32MB Cache Caviar
    Optiarc AD-5200A-0B 20X DVD±RW/DL Int IDE
    SB Audigy 2z
    p182 case
    case is open with no panels, temps on both cores 32'C roomtemp is a chilled 15'
    Windows Xp pro sp3
    Everything is running at stock
    HELP! I've put together a new build but been problems from start. At first it was working ok, then i was getting a blank screen at post but could hear windows boot up, then i moved the hd 4780 to the 2nd slot and all was ok for a couple of days and now nothing. Always a blank screen on boot, even after resetting the bios. So updated the bios to 0710 and tried a new gpu
    Ok So after a week of backed up post (snowy chaos!) i have a ati x600 128mb pci-e card in the mobo and guess what
    No more blank screen ... well kinda
    Put the card in, with one ram in slot a1, cpu/cooler, psu connected, powered up and the POST screen appeared! then it goes to this screen
    [​IMG]
    which is ok because no hdd attached yet
    so i reboot using the mobo switch and i get a blank screen followed by 1 long 3 short beeps on the "VGA bios" section of the lcd poster. SAME problem i was having with the HD4780 when it displayed a blank screen on post
    So i hit reset button a couple of more times, still blank screen. Power off, reset the cmos, and reboot.
    This time the POST appears on the screen, just the one beeps, then i get "cmos err" on the lcd poster and this screen
    [​IMG]
    f1 takes me to the bios
    f2 takes me the the first screenie i posted.
    if i go into the bios and when i exit (f1) or if i hit the reset button again (f2) i get the BLANK SCREEN on reboot and the 1 long and 3 short beeps on the vga bios section of the lcd poster
    So basically i cant see anything unless i reset the bios, which means any changes i make to bios to fix this wont hold?
    Any ideas ?
    oh bios screenies if they might help
    [​IMG]
    [​IMG]
  2. CH@NO
    CH@NO New Member
    May 24, 2007
    901 (0.32/day)
    59
    Toluca, Mexico
    maybe you don't wanna hear this but seems that your board came FAULTY, I have issues with an Asus board too, It came with the onboard sound dead, and I cannot OC at all, even with little OC the OS (any version) freezes, just using stock options the system remainded stable, now that I change the board for a Gigabyte one I'm very happy with the performance, simply I was unlucky when I buyed that Asus.
    I know you may wanted a better advice, but sometimes the HW fails and It's nothing you can do, just go with your reseller or RMA it, you DESERVE A GOOD board, and more taking about a high-end model like Rampage.
    ashwinc says thanks.
  3. ashwinc New Member
    Feb 12, 2009
    12 (0.01/day)
    0
    london
    thanks buddy, my gut says the same, well hopefully the rma will come through! Still not sure if the problem is the board or the hd4780, since i can see the screen on post with the x600, shame i cant save any settings in the bios though!
  4. CH@NO
    CH@NO New Member
    May 24, 2007
    901 (0.32/day)
    59
    Toluca, Mexico
    but even if you see the POST with your X600 you said you must reset the BIOS everytime doesn't it?, so It means the mobo has a problem, and if you can RMA it I say do It, just in case AND in the main time you should RMA the HD4870 just in case It came faulty too....when I upgrade my rig I ordered an Asus P5Q-E and a EVGA 9800GT, both came damaged, maybe you experienced the same worst luck than I.
    Good Luck mate :toast:
  5. ashwinc New Member
    Feb 12, 2009
    12 (0.01/day)
    0
    london
    well i've rma both, been told four days to to test, be shocked that both are faulty, but as u said, it happens. And yeah since the x600 worked (well it showed thepost after the bios is reset, and yeah after the computer is reset it will not display the post, unless u reset the bios as well:banghead:)i was thinking maybe its the mobo that is bad, but once i tried the same process with the hd4780, still blank screen. Guess i'll read my gta4 manual for the 100th time lol.
    By the way was your damaged Asus P5Q-E and EVGA 9800GT noticeable? Or did you like me have not idea what was wrong and had to rma?
  6. ashwinc New Member
    Feb 12, 2009
    12 (0.01/day)
    0
    london
    RMA report for hd 4780 - FAULTY! so refund on that one :rockout: ( no other details as to what failed)
    ok so now waiting on the mobo report....
  7. ashwinc New Member
    Feb 12, 2009
    12 (0.01/day)
    0
    london
    jeez, ebuyer uk, we got there in the end, mobo RMA's as faulty, new one due monday, finally!
Share This Page
