razaron's Physics Engine Project Log
Discussion in 'Programming & Webmastering' started by razaron, Jan 31, 2012.
  1. razaron
    razaron
    Apr 26, 2008
    1,107 (0.39/day)
    177
    london
    I'm currently making the physics engine for an action rpg.
    Here's the engine. You need Java and a gpu/igp that supports openGL.
    Controls:
    -Enter pauses/plays the simulation
    -R resets the simulation
    -1, 2 & 3 selects a shape
    -A & D rotates the selected shape
    Feature checklist(not done, half done, done):
    -Rigid bodies
    -Cloth bodies
    -Fluids
    -Variable masses
    -Variable friction coefficients
    -Variable restitution (bounce) coefficients
    -Magnetism
    -Destructible rigid bodies (cracking, breaking)
    -Destructible cloth bodies (tearing)
    02/02/2012
    -Added different shapes
    -Made the screen bigger (800*600)
    -Under the hood changes
    31/01/2012
    -Functioning rigid body simulator
    [​IMG]
    If it closes on start up try changing the first word ("java") in the batch file to the path of your Java executable. Make sure to include the quotes around path.
    E.g. Change java to "C:\Program Files\Java\jre7\bin\java.exe"
  2. Maelstrom
    Sep 10, 2008
    534 (0.20/day)
    159
    VA/PA
    So i DLed it, extracted it, and doubled clicked the "Start" batch file, and nothing really happened. CMD popped up for a second, but that's about it. Am I doing something wrong? I have java installed and I know my gpu supports openGL.
  3. cheesy999
    Jul 2, 2010
    4,021 (1.96/day)
    621
    UK
    5002 on a phenom II x4
    CPU-Z + screenshot --> [​IMG]
  4. razaron
    razaron
    Apr 26, 2008
    1,107 (0.39/day)
    177
    london
  5. helloWorld New Member
    May 29, 2011
    177 (0.10/day)
    32
    USA
    I have Java 6 Update 30 installed and the nVidia 290.53 drivers installed with a GTX 580, so I believe that I am good on the software and hardware installed.
    However, I am running into the same issue that Maelstrom ran in to. Every time I try to execute the program, a command prompt pops up and then disappears within a second.
  6. pantherx12
    pantherx12 New Member
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    When I get to around 70 polys I get a massive performance hit.
    System specs <--
  7. razaron
    razaron
    Apr 26, 2008
    1,107 (0.39/day)
    177
    london
    You have to change something in the batch file but I'm not sure what. Sorry.
    Odd. I can get to 105-110 polys before the performance drops.
    This is probably because I've coded it in Java 1.7 (then ran it using Java 1.7).
  8. razaron
    razaron
    Apr 26, 2008
    1,107 (0.39/day)
    177
    london
    Change the first word ("java") in the batch file to the path of your Java executable.
  9. theJesus
    theJesus
    Jul 20, 2008
    4,023 (1.45/day)
    912
    Ohio
    And make sure to keep the quotes so it doesn't parse the space in "program files"
    razaron says thanks.
  10. theJesus
    theJesus
    Jul 20, 2008
    4,023 (1.45/day)
    912
    Ohio
    I can't get much past ~135 polys without it crashing (I assume due to the squares having to overlap at that point). At 128 polys it was ~1000fps
  11. theJesus
    theJesus
    Jul 20, 2008
    4,023 (1.45/day)
    912
    Ohio
    You have to press enter to start the simulation.
    Maelstrom says thanks.
  12. Maelstrom
    Sep 10, 2008
    534 (0.20/day)
    159
    VA/PA
    Reading comprehension fail on my part xD. I'm an idiot. Thanks though.
    OK, 2nd go. At around 90 blocks the program just crashes. FPS was way above 60 when it happens.
  13. razaron
    razaron
    Apr 26, 2008
    1,107 (0.39/day)
    177
    london
    Next up; friction and "bounce".
    theJesus says thanks.
  14. Maelstrom
    Sep 10, 2008
    534 (0.20/day)
    159
    VA/PA
    DL'ed the new version. It's entertaining, but I made it crash again, this time at only 25 polys (I had shapes flying all over the place).
    Edit: got it to crash even quicker. I created 4 blocks very quickly in the same position and it crashed. It doesn't appear to know how to handle lots of stuff overlapping.
    Edit 2: Yep, it is an overlapping problem. I created 7 block in the same area, pressed enter, and this happened:
    [​IMG]
    Crashes if you try to create more shapes.
    Granted, that's not the way you're supposed to use it.
  15. razaron
    razaron
    Apr 26, 2008
    1,107 (0.39/day)
    177
    london
    I think the crash happens because something is divided by (a number very close to) zero, lol.
    For the next update I'll make it so you can't stack 3 or more shapes on top of each other.
  16. pantherx12
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Downloading new version, is multi-core support something you will be implementing at all?
    New version is a whole lot better got to 196 before the frame rate took a massive hit and then crashed.
    I'd say 170 would of been above 300 fps still though.
    Will retry ina bit.
  17. razaron
    razaron
    Apr 26, 2008
    1,107 (0.39/day)
    177
    london
    After I've finished the physics engine I'll try offloading it to the GPU. If that fails I might make it use 2 threads. This is because the engine is for use in a game with a VERY big scope, so I'll need other threads to handle AI etc.
  18. pantherx12
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Looking forward to GPU acceleration! :toast:
    Love apps that use my gpu XD
