Realtek HD ALC892 Onboard Card 5.1 Rear Speaker Problem
2 (0.00/day)
Hi everyone. Im newbie on this forum and ive bad english for this sory. Ive Asus P8Z64-V Pro motherboard and i cant get sound from the rear speakers in 5.1 surround sound if and when install a new version software/drivercauze its only supports side speakers in 5.1 surround sound. If i dont install a new version software/driver supports both 5.1 surround sound (side speakers in surround sound and rear speakers surround sound). The first picture following old version software/driver and second picture new version software/driver.
cadaveca
My name is Dave
17,232 (2.62/day)
You simply have to move the plugs around to get proper function, or use different driver. This is a problem in many motherboards.
cadaveca
My name is Dave
17,232 (2.62/day)
Ive also tried other drivers (asus, guru3d and dolby crack) but result is the same. Do you have another solution?
Nope, just move the plugs. Usually side/rear get swapped, so you need to move speaker plug for rears to side port, or vice-versa.
The only driver I have found to work 100% fully in the way you would expect is the one Windows installs itself. Any other driver will have this problem, I have found as you have.
