red CPU led
Discussion in 'General Hardware' started by iNgsane, Nov 25, 2012.
  1. itsakjt
    itsakjt
    Oct 9, 2010
    1,199 (0.62/day)
    403
    Kolkata, India
    Connect the motherboard speaker(beeper), remove the RAM and boot up. See if you hear a series of beeps. If yes- Your CPU and mobo is fine. I don't trust CPU LED. Also try resetting the CMOS via the jumper and also the battery-remove and remount everything from scratch final.
  2. iNgsane New Member
    Nov 25, 2012
    14 (0.01/day)
    0
    i've already reset cmos, made no diference and the battery seems to be unaccessable on this mb :(
  3. twicksisted
    twicksisted
    Oct 4, 2007
    2,438 (0.80/day)
    350
    out of interest, are all the fans running on the psu, cpu etc?
    If so, what brand/wattage PSU you running? and what other components do you have installed besides the mobo, chip & ram.... it could be that your power supply isnt up to powering it all.
    (If its a multi rail psu you may have everything running off one rail and the psu cant cope)
  4. iNgsane New Member
    Nov 25, 2012
    14 (0.01/day)
    0
    its a corsair tx850m
  5. twicksisted
    twicksisted
    Oct 4, 2007
    2,438 (0.80/day)
    350
    aaah ok scratch that suggestion then :D
  6. Doc41
    Doc41
    Sep 25, 2010
    509 (0.26/day)
    436
    Bahrain
    Do you not see anything at all on screen?
    for now i could only suggest you that you take out the cmos battery for at least 5min and to take out the cpu check pins and reseat it, if that doesn't fix the issue you might have done something during the move that resulted in this issue
  7. iNgsane New Member
    Nov 25, 2012
    14 (0.01/day)
    0
    nothing shows onscreen "no signal detected" i've already reseated the cpu, no diference. would it be safe to assume that its the MB thats broke? Should i buy a new one?
  8. cdawall
    cdawall where the hell are my stars
    Jul 23, 2006
    21,664 (6.21/day)
    3,538
    Houston
    Red CPU LED on my Crosshair V Formula as well ended up just shipping it off to Asus tried multiple CPU's, ram, VGA's etc. Hopefully yours is something simpler than that. I have one off my Xeon X3440, but it is an LGA1156 cooler so I do not know if it will fit. Assuming you are CONUS you can have it for whatever shipping is.
  9. iNgsane New Member
    Nov 25, 2012
    14 (0.01/day)
    0
    update guys, upon further close inspection of the motherboard, about half of the system panel connector(where you connect the power, restart, etc..case cables) has a brownish color, seems burnt and the restart button does not work, could this be the reason?
  10. itsakjt
    itsakjt
    Oct 9, 2010
    1,199 (0.62/day)
    403
    Kolkata, India
    Can you post a picture of the area?
  11. iNgsane New Member
    Nov 25, 2012
    14 (0.01/day)
    0
    i'll try
