Running out of ideas to fix this problem
Discussion in 'System Builder's Advice' started by MattMilne94, Dec 4, 2012.
Thread Status:
Not open for further replies.
  1. MattMilne94 New Member
    Nov 20, 2012
    100 (0.08/day)
    3
    no more replies :S
  2. TC-man
    TC-man
    May 25, 2011
    373 (0.22/day)
    131
    Netherlands
    Have you tried underclocking and/or loosing up the timings of the ram? Try that first if you haven't.
    As for memtest, how did you test the ram modules? one by one or all at the same time? If you already test them one by one at a time, then it's okay. Otherwise you need to retest them, one by one at a time. And how many sticks/ram modules do you have? 2x 4GB or 4x 2GB sticks? If it's 4 sticks you may need to set the northbridge voltage setting a little higher (test with small increments, just to be safe).
  3. FordGT90Concept
    FordGT90Concept "I go fast!1!11!1!"
    Oct 13, 2008
    17,116 (6.39/day)
    6,425
    IA, USA
    Do both of these.
    Crunching for Team TPU
  4. Jetster
    Jetster
    Jan 17, 2010
    7,342 (3.31/day)
    3,766
    Oregon
    Did you try what I suggested?
  5. MattMilne94 New Member
    Nov 20, 2012
    100 (0.08/day)
    3
    Sorry - it worked for 3 days fine but it crashed again.
    When i turned it back on I got this message on a black screen:
    "Checking file system on C
    Type of file system is NTFS
    One of your disks need to be checked for consistency, you may cancel the disk check but it is strongly recommended that you continue."
    It then restarted my computer and all was well again
    Could this mean that it has been my hard drive the whole time?
    Sorry for slow replies
    If this is the case - that it is the hard drive making the crashes happen what we would be a reliable HDD which is good for gaming?
  6. MattMilne94 New Member
    Nov 20, 2012
    100 (0.08/day)
    3
    anyone ?
  7. Crap Daddy
    Crap Daddy
    Oct 29, 2010
    2,831 (1.47/day)
    1,193
    What HDD you have and how old is it? Have you checked the event viewer, it might give you a clue of what caused the crash.
  8. MattMilne94 New Member
    Nov 20, 2012
    100 (0.08/day)
    3
  9. MattMilne94 New Member
    Nov 20, 2012
    100 (0.08/day)
    3
    and its only like 2 months old
  10. natr0n
    natr0n
    Jan 29, 2012
    2,883 (1.95/day)
    1,728
    FL.
    Play some games with your side panel door removed to see if heat is an issue. Don't overclock anything.
    If that doesn't work try another hard drive.
    If that doesn't work could be PSU.
    Do all your tests with the case door off though.
  11. MattMilne94 New Member
    Nov 20, 2012
    100 (0.08/day)
    3
    I have played games with the side panel off before and it still crashes
  12. natr0n
    natr0n
    Jan 29, 2012
    2,883 (1.95/day)
    1,728
    FL.
    what are your ram timings ?
  13. MattMilne94 New Member
    Nov 20, 2012
    100 (0.08/day)
    3
    how do i check those?
  14. natr0n
    natr0n
    Jan 29, 2012
    2,883 (1.95/day)
    1,728
    FL.
  15. MattMilne94 New Member
    Nov 20, 2012
    100 (0.08/day)
    3
  16. natr0n
    natr0n
    Jan 29, 2012
    2,883 (1.95/day)
    1,728
    FL.
  17. natr0n
    natr0n
    Jan 29, 2012
    2,883 (1.95/day)
    1,728
    FL.
    [​IMG]
    located here in your bios
    dram timing control
  18. MattMilne94 New Member
    Nov 20, 2012
    100 (0.08/day)
    3
    what does that dO?
  19. natr0n
    natr0n
    Jan 29, 2012
    2,883 (1.95/day)
    1,728
    FL.
    That memory timing can cause crashes and issues like you are having when set to 1.
    2 is usually always stable.
  20. MattMilne94 New Member
    Nov 20, 2012
    100 (0.08/day)
    3
    I've been reading on some other sites that that doesn't actually do anything...
  21. Jetster
    Jetster
    Jan 17, 2010
    7,342 (3.31/day)
    3,766
    Oregon
    If he ran memtest overnight with no errors then its not the memory.
  22. cadaveca
    cadaveca My name is Dave
    Apr 10, 2006
    15,044 (4.18/day)
    8,553
    Beaumont, Alberta
    I do not agree. In fact, I can get any kit memtestx86 stable, and still have it crash in OS under just light load.
    natr0n says thanks.
  23. drdeathx
    drdeathx
    May 14, 2009
    2,132 (0.86/day)
    479
    Chicago burbs
    For Pete's sake, will you report the exact temps of the system and the card?
  24. itsakjt
    itsakjt
    Oct 9, 2010
    1,199 (0.61/day)
    403
    Kolkata, India
    These types of random blue screens signifies problem with RAM or the memory controller. I have these when my system memory section is heavily overclocked and I test stability.
  25. natr0n
    natr0n
    Jan 29, 2012
    2,883 (1.95/day)
    1,728
    FL.
    Did you actually try it or are you looking for ways to avoid a fix when YOU asked for help?
Thread Status:
