Safe To Run 4 Pin CPU Fan On 3 Pin Connection?
Discussion in 'Overclocking & Cooling' started by DaveK, Apr 10, 2009.
  1. DaveK
    DaveK
    Oct 7, 2008
    1,889 (0.82/day)
    145
    Hey guys, I have this fat 120mm intake fan from my old Dell, it's 4 pin (PWM?) but wont work on the CPU fan connection...but it does work on the standard 3 pin connection, but I'm not sure it's safe, it's extremely loud and blows a lot of air, it's actually kinda scary lol
    lol http://www.youtube.com/watch?v=4FCFpS4k75c
  2. SparkyJJO
    SparkyJJO New Member
    Apr 2, 2009
    312 (0.15/day)
    33
    What are the current ratings on it?
    It is probably fine.
  3. r9
    r9
    Jul 28, 2008
    2,144 (0.90/day)
    284
    yes
  4. DaveK
    DaveK
    Oct 7, 2008
    1,889 (0.82/day)
    145
    12v, 1.30a.
  5. Chloe New Member
    May 6, 2009
    4 (0.00/day)
    0
    Thompsonville IL
    no, don't ever push more than 0.7a through a motherboard fan header, hook the fan directly to yer psu. otherwise it'll overload the motherboard voltage regulators.
  6. mlee49
    mlee49
    Dec 27, 2007
    8,499 (3.29/day)
    2,107
    youtube video has been removed... :(
    You'll be fine by running a 4 pin fan in a 3 pin slot. The last pin is for fan control and will just go unsupported. If you want to quite the fan down you may be interested in a molex modification to drop the voltage to 5V and then get an open pin adapter. That would require about 30 minutes of work/modding and about $5 for the open pin adapter, but would be a nice beginner's project.
    I suggest dumping the old thing and just get a nice, brand new, Sycthe S-Flex or the likes. :) $15 at Microcenter/Newegg. Ensured life span, super quite, and well worth the money.
  7. chuck216
    chuck216
    Mar 27, 2007
    632 (0.22/day)
    99
    Tampa FL
    It should be fine I'm running a 120mm x 38mm 1.5 amp fan out of a Dell 1600sc server off of one of the 3 pin headers, as my side panel fan it works fine. nothing like 160 cfm for case ventilation.
  8. silkstone
    silkstone
    Nov 1, 2008
    2,914 (1.28/day)
    514
    If in doubt you can get a fan hub. I just bought a Cooler Master Wind Rider. It has 6 PWM fan headers and cost me $15. It worked out a lot better than modding all my fans to fit.
Share This Page
