Samsung 840 SSD write speed absymally low
88 (0.01/day)
Processor QX9650, 4@1.36v 11x365
Motherboard Asus p45q-e
Cooling Prolimatech Super Mega Cooler (Akasa Viper push/pull)
Memory OCZ 8GB (4x2GB) PC2-6400C4 800MHz ReaperX HPC Enhanced Bandwidth Edition Dual Channel DDR2
Video Card(s) HIS 6970 ATI HD
Storage 1TB
Display(s) 30" dell 3008, 2x19" samsumg syncmaster
Case Antec P180
Audio Device(s) PCI XFi SB
Power Supply 800wat Tagan
Software Windows 7 x64
Benchmark Scores 14500 3dmark 06 @ 2500x1600 8AA 22000 3dmark 06 @ defaults 4800 3dmark 11 @ defaults
Hello clever people,
I just bought another SSD (Crucial MX100) and was benching it against my existing Samsung 840 which I use as primary partition. In doing so I get the following results:
Two disks:
..samsung 840 is 150/250gb full, ACHI on, condition good, write caching OFF
..crucial mx100 is 100/500gb full
Both are using
using ATTO:
Samsung 840 results: Awful write speeds :(
Curical results: Seems a good job, pretty fast and meets the stated specifications.
Any thoughts on what I can do to determine why the Samsung is performing like an old tart?
156 (0.04/day)
Australia
Processor Intel Core i7 9700KF @4.4
Motherboard Gigabyte Z390M Gaming
Cooling Noctua NH-U9S / NA-FC1+Noctua and Be Quiet! Fans
Memory Corsair LPX DDR4 32GB 3200MHZ
Video Card(s) Asus Dual RTX 3060 12GB
Storage Samsung 970 EVO 500GB NVMe
Display(s) MSI G244F + Dell P1914S
Case Be Quiet! Pure Base 500 Black
Audio Device(s) A] Onboard > Logitech Z623 B] Denon DRA-295 > JM Lab Cobalt 810
Power Supply EVGA G+ 650W with APC 1400VA UPS
Mouse Asus Strix Carry + Corsair MM300
Keyboard Ducky One 2 TKL MX Silver
Software Win 10 64Bit
840 EVO? Yeah they have an issue with degraded performance. But there is a firmware update to fix it i believe.
I own a 250gb and a 500gb 840 EVO but havnt seen any issues. I did update the firmware last week for the hell of it.
17,830 (2.67/day)
259 (0.07/day)
System Name maipc
Processor 4790k @ 4.4Ghz / 1.16v
Motherboard Asus vii hero
Cooling Noctua NH-D14
Memory 16GB (2x8GB) Hyperx fury 1866 / CL10
Video Card(s) MSI RTX 3060 Ti Gaming X 8GB
Storage 1TB 860EVO + 1TB 860EVO + 4TB WD Red + 4TB WD Red
Display(s) Asus VG259QM (1080p IPS 240Hz)
Case Cooler Master Centurion 6
Power Supply Seasonic Prime GX-650
Mouse Logitech G Pro X Superlight
Keyboard Wooting 60HE
Software Win 10 64bit
The common 840 EVO performance degradation issue is that read speed of old files is slow. Slow reads of new files and writes are not explained by it. You may have another problem.
Try another cable and port.
Aquinus
Resident Wat-man
13,147 (2.94/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Could we get a screenshot of the SMART attributes for the Samsung drive?
88 (0.01/day)
Storage 1TB
Case Antec P180
Okay, I think this is revealing.
Samsung 840 pro
New Crucial MX100 shows:
2,329 (0.46/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
flappyone
12 (0.00/day)
Samsung 840 pro
There are C7 - CRC Error counts. In 99% they are related to a lose or broken SATA cable. If the Cable is broken, the raw value will increase. You should change the cable and check the status again after a short time. Compare it. If the value stays at B5, it is fine. (It will not decrease or reset ever)
