Samsung 931BF problem - help appreciated
Discussion in 'General Hardware' started by spixel, Jun 29, 2008.
  1. spixel New Member
    Jul 16, 2007
    299 (0.10/day)
    11
    Recently i purchased a 931bf. It arrived boxed and sealed appearing new but once i powered it on i could notice quite a few ( 10 or so ) black smudges which appeared to be on the front of the monitor. However after trying to remove them it was obvious they were on the 'inside' of the monitor. How did this happen if the product is new? Does samsung sell damaged/refurbished monitors to retailers who sell them as new models ?
    Also is there any way to remove this , as it is quite annoying when playing games as in the middle of my crosshair is a big smudge :confused:
    If it can be removed i cant be bothered returning the product waiting weeks to recieve another. What do you guys recommend doing oh and again is there anyway to clean the inner side of the ' front layer '.
  2. spixel New Member
    Jul 16, 2007
    299 (0.10/day)
    11
    bump , really need some help ! :)
  3. CrackerJack
    CrackerJack
    Dec 13, 2007
    2,748 (0.92/day)
    462
    East TN
    I would send it back.
    refurbished monitors are only sold from retailers, not straight from Samsung. It's usually called an open box item too.
  4. spixel New Member
    Jul 16, 2007
    299 (0.10/day)
    11
    The box didnt look tampered with though. looks brand new until its turned on. you sure samsung dont sell just say b-grade items to retailers who then sell them at a low price? cause this monitor was quite cheap compared to other sites selling the same one.
  5. CrackerJack
    CrackerJack
    Dec 13, 2007
    2,748 (0.92/day)
    462
    East TN
    Where do you get at? Some retailer, maybe all retailer sell resell items that have been sent back due to damage and or just not happy with the product. But if there damage they get sent back to the manufactor, then repair. And sent back to the retailer to be sold again. But if the retailer doesn't see any noticeable damage, they'll just turn around and sell it again. Which is called an open box item.
  6. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    In a library somewhere on this earth
    The thing that happened is this.. Some person had that monitor, had something wrong with it, and returned it... The company that it was bought from then sent it to Samsung to have them fix it. Open box is a term that is used when one item has been sent back for ether not liking the product or a RMA... I'd say return it also because it was a thing they over looked.. They'll just send you a new one and be done.
  7. spixel New Member
    Jul 16, 2007
    299 (0.10/day)
    11
    Anyone think of a way to just fix the problem ? is it possible to clean the inner side of the front of the monitor.
  8. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    The only way to do that is to take it apart.. and even if you do, if you couldn't then RMA'ing would probably not be able to happen... It's just better to rma it, and get it over with.. IMPO
  9. spixel New Member
    Jul 16, 2007
    299 (0.10/day)
    11
    OK I FOUND THE PROBLEM , looking closley on the monitors box the samsung product sticker says EDC at the end of the product code. With a bit of googling i found out this means its a B-grade item (or an item returned for whatever reason under 30 day moneyback ) yet where i purchased it from failed to say this. Every other site have made sure to point out that is is EDC. Could i requet a refund from the company without having to return the monitor to them due to false advertisement ? Also what is EDC an abreviation for.
  10. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    I don't know what EDC stands for, but I would call them up and talk to them about it.. It is False Advertisement for them to do that because of the fact they have to GIVE ALL the numbers and not just some... Just call, tell them whats going on, and if they say prove it.. take pictures and go from there.... And if they don't like it.. threaten and so forth.. They are suppose to give you everything that is said on that monitor...
