Sandy Bridge Heatsinks. (Noise rating top priority)
Discussion in 'Overclocking & Cooling' started by Hotobu, Jul 10, 2011.
  1. Paulieg The Mad Moderator
    Feb 19, 2007
    11,960 (3.07/day)
    3,054
    Wherever I can find the iron.
    I understand, but he specifically asked for cheaper options. I can't see not going dual fans when it can make a 5c temp difference.
    10 Year Member at TPU
  2. cadaveca
    cadaveca My name is Dave
    Apr 10, 2006
    16,426 (3.90/day)
    10,797
    Parkland County, Alberta
    I gotta suggest D14 here too; I had one, and I miss it, and the C14 I got now just isn't as good.
    And...I can get a new one for $50!
  3. Paulieg The Mad Moderator
    Feb 19, 2007
    11,960 (3.07/day)
    3,054
    At $50, it's a bargain. It's just so damn big, and I think the OP is looking for something that doesn't dominate the board quite as much. Actually, that's the one reason I didn't keep mine. I don't regret switching out. The VX temps are quite similar.
  4. cadaveca
    Apr 10, 2006
    16,426 (3.90/day)
    10,797
    It IS very big, but I do not see that as any issue. It's also got very good ram clearance(mushkin ridgeback and G.Skill RipjawsX fit just fine)
  5. Hayder_Master
    Hayder_Master
    Apr 21, 2008
    5,229 (1.51/day)
    668
    IRAQ-Baghdad
    I have haf-x case and booth coolers the H70 and D14, the D14 is a bit better than H70, H70 it's some kind hard to install cuz it make remove my back fan in case and swap it from behind replace it with the other fan coming with H70, but after it all H70 make a good room in case and can put ram sticks with high heat sink or ram cooling, so it's back to u dude.
    I see if you take a look on H100.
  6. cadaveca
    Apr 10, 2006
    16,426 (3.90/day)
    10,797
    The H70 is much poorer performing than D14, here with my CPUs, nevermind that the H70 is exponentially louder. H100 might be a good alternative.
  7. KieX
    Dec 18, 2009
    2,406 (0.84/day)
    2,461
    London, UK
    Prolimatech Megahalems with push/pull Akasa Apache fans would be my suggestion. Very silent and performance is very similar to stock D14.
  8. Hotobu
    Hotobu
    Jun 29, 2011
    334 (0.14/day)
    63
    Thanks, but that would cost more than a D14. I do like those fans though.
    Well I wont be ordering parts for another 3 weeks, but as it stands now I'm leaning towards going with the Venomous X with 1 Akasa Apache fan. As far as I can tell this is a a compromise of a few of the suggestions. Unfortunately due to me having to get the fan and heatsink from two separate stores, them charging a lot for shipping, and Newegg's free shipping on the D14 I only save $20, but that's something. Also... let's face it the fan colors on the D14 look like somebody's grandmas couch.
    Thanks everyone.
  9. Paulieg The Mad Moderator
    Feb 19, 2007
    11,960 (3.07/day)
    3,054
    You're welcome. You'll be happy with the VX. From mounting to performance, it's really a great cooler for the reasonable price, especially with the right fans. Amazon has the F3 fans for $10 a piece, if you're interested in them.
  10. Pestilence New Member
    Apr 5, 2011
    587 (0.25/day)
    67
    Has the OP stated what case he plans on running? Case is the main priority. Putting a high end heatsink in a case with shitty airflow is just a waste of money
  11. Hotobu
    Hotobu
    Jun 29, 2011
    334 (0.14/day)
    63
    haf x
  12. Pestilence New Member
    Apr 5, 2011
    587 (0.25/day)
    67
    Any heatsink will be fine then.
  13. Zen_
    Zen_
    Apr 18, 2010
    499 (0.18/day)
    115
    Hyper 212 with two decent PWM fans. Cheaper and less hassle than the D14 / Silver Arrow / Corsair Hydro.
  14. sneekypeet
    Apr 12, 2006
    24,444 (5.80/day)
    9,326
    This is an interesting thread.....a ton of 300W coolers get mentioned to only cool 125-150W of CPU power?
  15. Pestilence New Member
    Apr 5, 2011
    587 (0.25/day)
    67
    People enjoy overkill sneaky
  16. Paulieg The Mad Moderator
    Feb 19, 2007
    11,960 (3.07/day)
    3,054
    Well, I can say that when a 2600k or 2500k is overclocked to 4.5ghz or higher, a high performance cooler is quite justified, as temps can and will reach 70c+ load temps on even the best of the 300w coolers, even with the lack of HT on the 2500k.
  17. Hotobu
    Hotobu
    Jun 29, 2011
    334 (0.14/day)
    63
    :/ I shoulda thought of this earlier... decisions decisions. I'm always happy to actually have enough choices to make a decision though. While I can probably make this quieter than a stock 212 and am willing to sacrifice some cooling for sound it's hard to figure out just how much performance I'm losing by with so many non stock options. Again, thanks for everyone's input
  18. Pestilence New Member
    Apr 5, 2011
    587 (0.25/day)
    67
    I have to disagree with you paul. I run my 2500K with a 3 heatpipe rocketfish cooler.. The one below and at 4.5Ghz i don't break 65C with IBT. I attribute those amazing temps to my Antec 1200. A great case makes all the difference.
    [​IMG]
  19. Paulieg The Mad Moderator
    Feb 19, 2007
    11,960 (3.07/day)
    3,054
    The 212 is a good budget cooler. If you are willing to lose a bit of cooling power on the top end, then it is a good choice, but you will want to replace the fan for sure.
    I believe that is a rebadge 212. You are right about the case making a huge difference. Can you do me a favor and do a IBT run on at least very high for 10 cycles, and post a screenie with temps? I don't mind being wrong here, but I'd like to see it.
  20. sneekypeet
    Apr 12, 2006
    24,444 (5.80/day)
    9,326
    I was just running my 2600K on some Shagon' AHC-118, and in no mixed words, its poop for a cooler. I have to say it did a fine job, and I wasn't in the 70's at 4.5, and I need almost 1.4V to do even that;)
  21. cadaveca
    Apr 10, 2006
    16,426 (3.90/day)
    10,797
    Haven't met a chip that needed more than 125W of power to do 4.5 GHz...ergo doesn't need that much cooling.
  22. Paulieg The Mad Moderator
    Feb 19, 2007
    11,960 (3.07/day)
    3,054
    It's possible that I have a couple of chips that run hot on one of the cores. I'd still like to see some screenies of 4.5 on these budget coolers with IBT on very high. Post them up. One of my chips is quite good, and even with the VX, one of my cores reaches 65c. Now prime 95 is a different story, so if that is the standard then I understand. I don't break 60c in prime.
  23. Bo$$
    Bo$$ Lab Extraordinaire
    May 7, 2009
    5,617 (1.82/day)
    970
    London, UK
    I can vouch that it is whisper slient. and cools fairly well
  24. cadaveca
    Apr 10, 2006
    16,426 (3.90/day)
    10,797
    You must not be running the newest version of prime..it gets hotter than IBT does, and I'm IBT'ing with 7.2 GB.
    4.5, I'm about 65c, IBT or Prime, with the Noctua NH-C14. the chip that I use in the review rig hits 72c.
    Paulieg says thanks.
  25. Pestilence New Member
    Apr 5, 2011
    587 (0.25/day)
    67
    Will have a screenshot up for you later paul
