Sapphire Ati x1650 pro 512mb PCIE BIG PROBLEM pls help!!!!!
Discussion in 'Graphics Cards' started by krivis, Nov 14, 2007.
  1. krivis New Member
    Nov 14, 2007
    2 (0.00/day)
    0
    Pls people help me.
    I have Sapphire ati x1650 pro 512mb pcie.
    The problem showed up 3 days ago.
    So when the computer is booting the screen is filled with lines yelow blue red bla bla etc. i cant even reinstall windows because i cant read anything. SO when is booting there are lines but when enters in Windows Xp everything is ok, the picture is steady. I know that is the graphic card problem because i updated my motherboard bios and everything is the same. i have two monitors attached and the lines are the same on both. Maybe the bios is messed up.
    Someone pls make bios dump from the original bios and send it to me on pls people.
    Or maybe someone have a fix for this problem...
    THX
  2. BullGod
    BullGod New Member
    Nov 3, 2007
    412 (0.15/day)
    31
    Medias City
    Well... I'm sorry to say this but your card is probably fried. I don't know any way to fix this other than changing the card... Same thing happened to me with my 6200, I'm on integrated graphics for now and looking for a replacement.
  3. Dandel New Member
    Aug 1, 2007
    102 (0.04/day)
    4
    I agree with BullGod on this one, definitely time to replace the card, and the first stage is to try to RMA the card and get a cheap spare for now.
  4. rick22
    rick22 New Member
    Sep 4, 2006
    629 (0.20/day)
    34
    How long have you had this card? one thing you could do before you trash or rma it is to take the card a part clean it and put some artic silver #5 ...put it back together and try it again..good luck
  5. von kain New Member
    Sep 13, 2006
    782 (0.25/day)
    49
    athens/greece
    what it make me wonder is that the problem is on bios make an bios update.if you can on both video and mobo then write back
  6. krivis New Member
    Nov 14, 2007
    2 (0.00/day)
    0
    i can do on both update i made on the motherboard and nothing, but for the graphic card i cant find any bios.
    What is artic silver and where to put this silver
    And also i will try to RMA my card.
    But if any one have the bios dump of " sapphire ati x1650 pro 512mb pcie" pls send it to me or post it here.
    thx
Share This Page
