Sapphire HD4670 512MB GDDR3 problems. Help needed! :'(
Discussion in 'AMD / ATI' started by mudkip, Jan 21, 2009.
  1. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.47/day)
    148
    The Netherlands
    Sapphire HD4670 512MB GDDR3 problems. [Solved + NICE Overclock =D ]
    Problem is solved!
    I got these errors because Realtek R13 audio drivers were installed ,for getting Audio via hdmi, uninstalling realtek solved all my problems!!
    MAX HD 4670 OC , playable:
    http://www.techpowerup.com/gpuz/wp88x/
    MAX OC not playable:
    http://www.techpowerup.com/gpuz/9srpz/
    Good evening gents
    I've a problem with my Sapphire HD4670 512MB GDDR3, i have the HD4670 since a week or so.
    There's a list with problems..where to begin?
    When I installed catalyst 8.12 drivers for the first time I got an error ,something like ''INF driver wasn't found'' .
    [​IMG].
    But catalyst continued installing after I clicked OK.
    After catalyst was ready with installing I had to reboot my computer. After I rebooted I got another error something like this: No card was found . Then i installed catalyst again rebooted and everything worked fine?!
    Okay that was problem one.
    2nd problem :
    When vista is booting up I got stuck at ''Vista loading'' bootscreen.
    First I thought that it was because I didn't disabled extended desktop before turning windows off. Well that worked for a while but now it doesn't. I have to reset my computer a few times to make it boot. WHAT THE F*CK IS GOING ON?
    3rd problem:
    When videocard is connected to My LCD television via 2nd DVI there's another problem.
    When I select ''input'' HDMI 1 on my television before enabled extended desktop via catalyst both screens begin to flash . like they're turning on and off!
    WTF
    4th problem:
    When I enable ATi overdrive and select custom clocks and apply them ,nothing changes!
    But it worked in the beginning!
    Things I've tried:
    -Remove drivers
    -Driversweeper
    -Install drivers again
    -Connect videocard only to one screen (Main 19'' screen)
    -No overclocking
    My setup:
    P4 516 3Ghz
    1GB PC3200
    Gigabyte 915PM motherboard (With full PCI-e x16)
    Aopen 400Watt
    and ofcourse Sapphire HD4670 512MB GDDR3
    Screens:
    [​IMG]
    [​IMG]
    Is this a broken card? Or driver issue? And if so what can I do to prevent it in the future?
    Update: I think the card is broken somehow I requested RMA
    Problem is solved!
  2. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.47/day)
    148
    The Netherlands
    anyone?
  3. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.47/day)
    148
    The Netherlands
    bump HELP PLEASE
  4. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.47/day)
    148
    The Netherlands
    another bump
  5. buggalugs
    buggalugs
    Jul 19, 2008
    1,061 (0.38/day)
    200
    Australia
    If you look on the sensors tab of GPUz it will give the current value. The first page just gives you the default clocks.
  6. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.47/day)
    148
    The Netherlands
    Yes I found that out already! Clocks changes when GPU is stressed.
    But I still have the problem that the computer won't boot with 2nd DVI enabled.
  7. crtecha
    crtecha New Member
    Dec 8, 2008
    2,407 (0.92/day)
    207
    ipsay meechigan
    ditch ccc just install the drivers and use rivatuner to OC and use gpu-z for temp and clock stats. 8.12 is a pain.
  8. mav2000
    mav2000 New Member
    Nov 26, 2008
    451 (0.17/day)
    53
    Bangalore, India
    looks like you have a driver problem, something conflicting with the video card. Would suggest a clean install of vista. That should solve your problem.
  9. crtecha
    crtecha New Member
    Dec 8, 2008
    2,407 (0.92/day)
    207
    ipsay meechigan
    is the onboard vga disabled? and are the nvidia driver uninstalled? I used to have that board and it would blue screen then I disabled my onboard vga and made sure there was no sign of the drivers and I was fine.
  10. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.47/day)
    148
    The Netherlands
    I have no onbaord VGA, I didn't have a nVidia card..
  11. Jakl
    Jakl New Member
    Nov 18, 2008
    515 (0.20/day)
    50
    Home
    It seems like a corrupted Drivers on your system... Did you first UNINSTALL the drivers before installing them? Sometimes files get corrupted when they are over written.. I would recommend uninstalling all Video Drivers, reboot your system with no drivers , then downloading the latest one from the manufactures website.
    And I would recommend uninstalling any utility tools to Overclock your GPU, or anything related to your GPU
  12. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.47/day)
    148
    The Netherlands
    Yes I did uninstall the old drivers also I used driversweeper..I installed catalyst 8.12 from AMD but haven't tried installing with the drivers from sapphire yet..but i assume they're the same? I will try it though... I'm currently running on 8.11 but it makes no difference so I could better upgrade to 8.12
  13. Polarman
    Polarman New Member
    Jun 24, 2008
    1,627 (0.58/day)
    292
    Rimouski
    I installed the same Video Card in my brother-in-law's pc and did not have any issues installing 8.12. Everything ran fine.
    This was on fresh XP install btw.
  14. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.47/day)
    148
    The Netherlands
