sapphire radeon X800 GTO^2 problem
Discussion in 'Graphics Cards' started by Aevum, Jan 8, 2006.
  1. Aevum
    Oct 26, 2005
    642 (0.18/day)
    Madrid, Spain
    i have a slight problem with my sapphire X800 GTO^2,
    i´ve always had a problem when passing 540mhz memory frequency, no problem, i thought i had 2.0ns like some of the GTO^2 on the market,
    when pushing beyond that value and and run the artifact tester on ATItools, the machine would reboot after a couple of minutes of testing,
    the issue rose when a couple of days ago, i replaced the stock cooler with a zalman VF700-AlCu, on noise issues, when i pull off the stock cooler, 1.6ns memory chips,
    whats going on here ? heat problems ? voltage problems ?
    any suggestions ?
    another issue i´ve noticed, the memory chips on the back are only cooled by a patetic strip of aluminium which is actually used to keep that cooler in place, the VF700 came with individual aluminium memory heat sinks, i have´nt had the time to test how far the memory would go on those heatsinks, i wonder if those chips on the back of the card would be the problem.
