saving power with HD 6950/6970
91 (0.01/day)
Slovakia
Processor Core i7 5820k
Motherboard MSI x99s Mpower
Cooling Zalman Reserator 1, XSPC RX120, Koolance QDCs, Koolance MVR-40, EK Supreme HF, EK vga supreme HF
Memory 4x8GB crucial 3000MHz
Video Card(s) R9 290x 4GB with EK fullcover waterblock.
Storage Intel SSD 330 180GB, Samsung HD103UJ 1TB, Seagate ST31500341AS 1,5TB, Seagate ST4000DM000 4TB
Display(s) HP LP3065 30"
Case Silverstone Fortress FT02B
Audio Device(s) ATI HDMI audio device -> Yamaha RX-V1600
Power Supply Corsair AX860 80plus platinum
Software Windows 8.1 prof. x64 eng retail.
Hello. I have a problem with my new Radeon HD6950. I successfully flashed the card with 6970 bios. I'm using 2 outputs from my card - (1.) dual link DVI to 30" monitor (2.) HDMI to my AV-receiver just for sound (desktop at low resolution that I can't see).
The problem is that the card is in idle at 500MHz/1375MHz. What can be done to lower the power consumption? What if I lower the frequencies? Will UVD still work at lower frequencies? How to test if the card is still stable if I lower the voltage at those frequencies?
Any advice?
1,683 (0.32/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
All AMD cards maintain the higher clocks when more than one monitor is connected. This is normal. I believe that display corruption occurs if you were to lower the clocks with more than one display connected.
VinnieM
7 (0.00/day)
You can try lowering VID1 in RBE. The default is 1000mV and I've lowered it to 900mV. Any lower crashes my system when watching Youtube or anything else that stresses the card enough to go to 500MHz.
Lowering the frequencies might be possible with the latest MSI Afterburner, which allows setting up custom profiles and voltages. Too bad you can't alter it (yet?) with RBE.
91 (0.01/day)
Slovakia
Interesting...
Here is complete table of frequencies and voltages that shows GPU-Z 0.5.1 in single/dual monitor setup with default/6970 BIOS
Code:
default bios
single monitor idle 250/150 @0.900v
single monitor uvd  500/1250@1.000v
single monitor 3d   800/1250@1.100v
dual monitor idle   450/1250@1.000v   <- 450MHz core is not even listed in Clock info modes in RBE 1.27
dual monitor uvd    500/1250@1.000v
dual monitor 3d     800/1250@1.100v
6970 bios
single monitor uvd  500/1375@1.000v
single monitor 3d   880/1375@1.175v
dual monitor idle   500/1375@1.175v  <- same voltage than in 3D???
dual monitor uvd    500/1375@1.000v  <- lower voltage than in idle???
dual monitor 3d     880/1375@1.175v
Now I don't know what's wrong... GPU-Z? RBE? BIOS?
Does anyone know how to measure the GPU voltage with a multimeter?
Amorpheus
9 (0.00/day)
You can try underclocking manually, it seems that having the second output on at all is enough to trigger the "oh, two monitors, better keep my clocks up" mode. But I don't know of any tools that currently do that; Afterburner allows 50% of default clocks at the lowest and RivaTuner apparently needs an update before it will work with 69xx cards.
Another solution would be to buy a dirt-cheap card just for the additional outputs; I got a 4350 a while ago to hook up my TV as third monitor. Since I discovered that the high idle clocks were caused by using two outputs on my new 6950 I just hooked my second monitor up to the other card.
I ran my 4870 for over a year with a dual-monitor setup and idle clocks at 20% or so. No issues at all. I'm sure there must be some reason why they do that, possibly stability on some setups, but I don't think it should keep anyone from testing it out.
BAGZZlash
RBE Author
587 (0.09/day)
Code:
I suppose these values are set directly by the driver. Try looking into your XML profile. :toast:
If you ask him kindly, maybe JimmyZ will help you. He knows incredibly much about that suff and is a great guy too. :rockout:
91 (0.01/day)
Slovakia
Do you mean c:\Users\user_name\AppData\Local\ATI\ACE\Profiles.xml ?
450MHz is not there, only 250,500, and my overclocked 950mhz
BAGZZlash
RBE Author
587 (0.09/day)
Yeah, I meant this one. Strange, in that case I don't know where these 450 MHz do come from... :shadedshu
91 (0.01/day)
Slovakia
BTW. RBE can't open my profiles.xml. Error message says "error loading profile file".
See attachment...
EDIT: GPU-Z definitely reads GPU voltage incorrectly. I was playing with afterburner, changing core voltage and core clock in 3D. Afterburner's HW monitor was showing correct voltage while GPU-Z was showing constant 1.175v.
I reached a stable 915MHz core clock with 1.100v :)
EDIT2: OK, I lowered VID1 to 0.960v, anything lower hangs my system. Any change in clocks resulted in BSOD on boot.
EDIT3: I tried to measure difference of power consumption of my entire PC, here are the results:
idle single monitor 122w
idle dual monitor 168w
idle dual monitor with lowered VID1 to 0.960v 166w :mad:
  • Profiles.zip
