Should I change my Essence STX for a Creative SB Z sound card ?(for a better surround)
Discussion in 'Audio, Video & Home Theater' started by Okinoko, Aug 21, 2014.
  1. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    Hello !
    I apologyze in advance about my english (i'm french).
    I actually got a Xonar Essence STX sound card. It sounds very good for music but, in games especially in FPS games the surround isn't that good.
    I was thinking to buy a new Sound Card for a better surround especially the Creative Sound Blaster Z. Is that worth to buy it for a better surround ?
    Help me guys, i'm glad to get the Essence STX but I really want to have a beter surround.. :(
    I'm so confused. I already tried Razer Surround but there is a delay of any sounds :(
    I will apreciate any help from you guys !
    Thanks in advance !! :D
  2. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    10,345 (6.42/day)
    2,479
    Seattle, WA
    What are you using for speakers? That will make a bigger difference than sound card.
  3. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    I'm only using my Stereo Headphones (My MMX-300)
    Another tips ?
  4. X71200
    X71200
    Jun 23, 2014
    105 (0.48/day)
    29
    Keep the Xonar. Build wise it's a far superior sound card. I had a SB-Z and my X-Fi Home Theater HD handles it it's ass, let it be in games or in music. Sure, it was also a far more expensive card but still that point holds.
  5. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    Thanks alot for your reply ! :D
    Another tips ?
  6. fullinfusion
    fullinfusion 1.21 Gigawatts
    Jan 11, 2008
    8,505 (3.31/day)
    2,236
    So what are you talking about... Surround using the headset as virtual surrond or speakers?
  7. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    Sry, I meant Headset as virtual surround ^^
    Is that worth to change ? :/
  8. OneMoar
    OneMoar
    Apr 9, 2010
    4,187 (2.39/day)
    1,429
    Rochester area
  9. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    Thanks for your reply !
    The STX is a far superior then the creative even for a virtual surround ?
  10. OneMoar
    OneMoar
    Apr 9, 2010
    4,187 (2.39/day)
    1,429
    Rochester area
    if its configured properly yes the headset you are using is not good for fps its a
    install the uni-drivers and then tune the 3d boost function in viper
    this is my config
    [​IMG]
    viper will widen the audio witch is probably what you want
  11. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    Wow it looks awesome where can I grab viper ? Install uni driver ?
    I already installed Uni Xonar driver but I never see this Oo
    Thx!
  12. OneMoar
    OneMoar
    Apr 9, 2010
    4,187 (2.39/day)
    1,429
    Rochester area
  13. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    There is no effect at all. I can't see the difference maybe should I install Xonar Uni Driver ?
    Thanks!
  14. OneMoar
    OneMoar
    Apr 9, 2010
    4,187 (2.39/day)
    1,429
    Rochester area
    make sure you enable it via the power switch in the program and then reboot
    remember you need to manually configure the effects before it will work
  15. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    Okay thanks ! I try this !
  16. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    I enabled this then reboot and i got no effect :/
    Should I install Uni Xonar Driver ?
    Thanks!
  17. OneMoar
    OneMoar
    Apr 9, 2010
    4,187 (2.39/day)
    1,429
    Rochester area
    here is my preset http://cl.ly/XAKA/3d-expand+mutlitweak.vpf
    save it someplace and load it via the menu
    you may adjust "image size" and "space size" for more or less 3d effect
    small image size + large space size = wider
    large image size + small space size = tighter more focused can distort
    the preset I posted uses very little 3d expansion and MINIMAL effects
    if the program won't function make sure the power button slider is ON and that you are running the uni-drivers
    make sure you are running the program as admin as well
    viper is very powerful but can be difficult to master
  18. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    Really guy thanks alot i'll try that ! I have the default Xonar Audio Center. Am I obliged to install Uni-drivers or not ?
  19. OneMoar
    OneMoar
    Apr 9, 2010
    4,187 (2.39/day)
    1,429
    Rochester area
    I have only tested viper on a xonor dx running uni I do not know for sure if the factory xonar drivers are compatible with viper
  20. fullinfusion
    Jan 11, 2008
    8,505 (3.31/day)
    2,236
    Have you installed the latest Asus BETA driver?
    I had the same card and I never had issues in FPS games. Nothing a little EQ tweak here and there didn't fix ;)
    Plus what Impedance is that headphone? are you using the built in AMP? Crank it up! o_O
  21. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    Okay thanks! I will test that tomorrow, don't forget me !! ^_^
    Have a good night :)
  22. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    I meant the noises position in FPS games aren't that good. I have a 32Ohms Stereo Headphone, why ?
    And yes, I installed the latest Asus BETA driver for Windows 8.1 : (
    Thanks!
  23. OneMoar
    OneMoar
    Apr 9, 2010
    4,187 (2.39/day)
    1,429
    Rochester area
    what FPS are you playing and you need to explain more clearly about the problem you believe there is we are having difficulty understanding what you mean by "surround" if you mean like footsteps and enemy position installing a "creative" card will not help that at all that`s down to the game and your own ears
    if you mean down-mixing 7.1 or 5.1 SOURCE audio to stereo you can do that via the ASUS sound panel I know of no game that would benefit from that tho
  24. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    Yea, I wish have the same render as razer surround sound but without any delay. I just need a good virtual surround sound without "reverberation" like Dolby.
  25. Okinoko New Member
    Aug 21, 2014
    16 (0.10/day)
    0
    Could you guys help me about this ? :/
    Thanks
Share This Page
