Should I use DVI for my PC-monitor connection? And use the VGA port for my Xbox360?
Discussion in 'General Hardware' started by KKSlider1337, Jan 5, 2009.
  1. KKSlider1337
    Dec 7, 2008
    116 (0.04/day)
    3
    UK
    Hi there,
    My computer only seems to work through the DVI port, and I when I got it I got a DVI-VGA adaptor, and was using that connected to a VGA lead, then to my monitor. Got a new monitor/TV combo though with an actual DVI port.
    I don't have any DVI leads to my knowledge, so my question is would I get any benefit from buying one and using that? And is there anything I should take into consideration, e.g. the type or quality of the lead I buy (I don't really know anything about them.)
    Secondly, my 360 is also connected to this TV, so if I freed up the VGA port would I then get a benefit from buying a 360 VGA lead to connect it by that, or should I stick to component?
    My TV/monitor is an LG M2094D, 1680x1050, 720p.
    Thanks in advance.
    Now playing: Cynic - Integral Birth
    via FoxyTunes
  2. HolyCow02
    HolyCow02 New Member
    Jun 8, 2008
    1,638 (0.58/day)
    111
    New York
    For the 360, stick with component. Since the 360 comes with a component cable, no need to buy something that will show zero difference. As for the monitor, did it not come with a DVI cable? All of the monitors I have ever bought came with the cable necessary..
    What kind of video card do you have? Does it have DVI? If so, use that.
  3. KKSlider1337
    Dec 7, 2008
    116 (0.04/day)
    3
    UK
    Nah, the monitor came with another VGA cable, as it supports both. So I was wondering if it would look better with DVI.
  4. zithe
    zithe
    Jun 16, 2008
    3,144 (1.12/day)
    405
    North Chili, NY
    DVI is pretty much the same as HDMI. DVI/HDMI are digital, while VGA/Component are analogue(I believe). I believe both have the same max resolution, but I've noticed HDMI/DVI have richer colors.
    KKSlider1337 says thanks.
  5. WarEagleAU
    WarEagleAU Bird of Prey
    Jul 9, 2006
    10,811 (3.08/day)
    547
    Gurley, AL
    Use DVI there is a discernible difference between DVI and VGA.
  6. pepsi71ocean New Member
    Nov 7, 2007
    1,471 (0.49/day)
    125
    The Peoples Republic of New South Jersey
    DVI i would say for the computer. My monitor didn't come with a DVI just a VGA. however i love the rich color that DVI has over VGA. I would then go VGA for the xbox.
  7. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.32/day)
    573
    New York
    The gaming console I have know idea ...but the Monitor should be DVI my friend as thats your Hi Def out put from your Vid card:toast:
    720P is considered hi def ..its just the low end .
  8. KKSlider1337
    Dec 7, 2008
    116 (0.04/day)
    3
    UK
    Thanks for all the replies guys :)
    Looks like I have some cable shopping to do. Does it matter if the leads are particularly high quality?
    Also, you can get dual-link or single-link DVI, in DVI-D, DVI-A or DVI-I. I'm guessing I should get a DVI-I or DVI-D lead.
    The 360 VGA leads have a red and white audio output on them, I suppose I have to plug them straight into my stereo and that it wouldn't work if I just plugged them into the component on my TV, because VGA input would be selected at the time? If so, that would be a bit of a pain.
