sli mode problem...help
Discussion in 'Graphics Cards' started by newmodder, Feb 7, 2006.
  1. newmodder New Member
    Sep 9, 2005
    669 (0.19/day)
    7
    british columbia
    everytime i restart my computer it asks to install nvidia and detects another video card.i uninstalled everything nvidia and reinstalled and it still does it...what do i do?
  2. trog100 New Member
    Dec 18, 2005
    4,420 (1.28/day)
    237
    isnt there something u have to do in the drivers to tell your system its sli.. ???
    in one way windows is perfectly correct in finding new hardware cos there is some.. if the drivers dont tell it otherwise i can see why its doing it..
    trog
  3. bruins004 New Member
    Sep 27, 2005
    2,480 (0.70/day)
    75
    Do you have the release 80 drivers? Also, "before installing new drivers, make sure you uninstall all NVIDIA display drivers from the Windows Control Panel. Browse to the Start Menu > Windows Control Panel > Add/Remove Programs, and search for "NVIDIA Drivers" or "NVIDIA Display Drivers," and select remove NVIDIA Display driver only. Reboot and install the new drivers" (taken from Nvidia website). Just go here and check the FAQ sections (http://www.slizone.com/page/slizone_faq.html#c6).
Share This Page
