Small(big) problem with Cpu
Discussion in 'General Hardware' started by Snipe343, Dec 31, 2007.
  1. Snipe343
    Snipe343
    Jul 31, 2007
    1,002 (0.32/day)
    34
    Well i was dusting my computer(canned air) and i went to take my heatsink to the cpu because for somereason there was dust under it and i couldnt get to it. Any way i went to take it off the the CPu came with it:eek:, what happened?? nothing seems to be broke but the cpu seems glued to it. Also any way to fix it(dont really care i would like an upgrade but would be good to use as spare cpu)
    ALso forgot to put in that it came right off, didnt force or feel resistance at all
  2. erocker
    Jul 19, 2006
    41,064 (11.75/day)
    16,188
    How do the pins look? It's not glued.... If things look ok, just put the thing back in, clean off the old paste with some alcohol and reapply new paste and heatsink
  3. Snipe343
    Snipe343
    Jul 31, 2007
    1,002 (0.32/day)
    34
    how can i put it back in i still cant get the cpu off
    Pins look fine nothing seems out of line
  4. sneekypeet
    Apr 12, 2006
    22,837 (6.35/day)
    7,399
    should be able to gently twist it loose from the cooler
    Snipe343 says thanks.
  5. Beertintedgoggles
    Beertintedgoggles
    Nov 15, 2005
    772 (0.21/day)
    244
    That happened to me with my Opteron, the socket still had the latch pulled down and everything. If you didn't use anything like liquid metal on an aluminum heatsink or thermal epoxy then this is how I removed mine. I pushed on the edge of the PCB making sure not to bend any pins and sort of scooted the processor to the edge of the heatsink and removed it that way. I also tried using a twisting motion to break the adhesive bond between the CPU and heatsink but I didn't really want to put much pressure while trying to pry it off at the same time. The only trouble with the way I removed it is you may leave scratch marks on the IHS or heatsink. I didn't mind with mine because I lap my heatsinks everytime I take them off and I was removing the CPU to cut off the IHS anyway.
    10 Year Member at TPU
  6. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.11/day)
    3,777
    Yep.
    I had this happen to me once. It's as Sneeky said, you just have to try twisting it off.
  7. Snipe343
    Snipe343
    Jul 31, 2007
    1,002 (0.32/day)
    34
    ok thanks it came off
  8. Lazzer408
    Lazzer408
    Jan 6, 2007
    2,550 (0.77/day)
    342
    Illinois
    In the future, if you guys get a really stuck one, use a few drops of charcoal lighter fluid and allow it to soak in. It'll disolve thermal compound quite nicely and doesn't evaporate very quickly giving you time to work. ;) Also good for clean-up.
  9. btarunr
    31,316 (10.27/day)
    15,522
  10. Lazzer408
    Lazzer408
    Jan 6, 2007
    2,550 (0.77/day)
    342
    Illinois
