Small Cool and Silent?
Norton
Moderator - Returning from the Darkness
14,108 (3.13/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
width is fine, it's the depth that matters to me, my p180-min is 8.3" wide and 17.2" deep any deeper and it'd stick out
The TJ-08 is less than 16" deep so no trouble there- that case is crazy big inside... you may even be able to stuff a Noctua NH-D14 in it (check w/Silverstone first though)
washd123
50 (0.01/day)
that cooler is massive, I'd rather not, I had bad experiences working with large coolers like the zalman CPNS9900LED my hands were bleeding
Norton
14,108 (3.13/day)
Northeast USA
Mouse G300s
VR HMD N/A
Well the the Xig Gaia is a lot smaller and kept my system cool and quiet. The mounting system is very solid and cost is only about $30 in the US.... most towers in that size class should work fine but I would need to know what kind of hardware you were planning to use to say for sure.
washd123
50 (0.01/day)
MSI GTX560TI HAWK
4GB corsair DDR3 ram
MSI z68 mobo (maybe z77) microATX
OCZ ZT 750w modular psu
Scythe 900RPM 120mm fans
TJ07 case
Norton
14,108 (3.13/day)
Northeast USA
Mouse G300s
VR HMD N/A
5,976 (1.08/day)
Cybertron aka Canada
Processor Intel Core i5-3570K
Motherboard Asus P8Z77-V Pro
Cooling Noctua NH-D14
Memory 8GB Mushkin Blackline DDR3-1600
Video Card(s) Gigabyte GTX 670
Storage Intel 520 60GB, Seagate Barracuda XT 2TB
Display(s) BenQ 24" XL2420T
Case Corsair 550D
Audio Device(s) Sennheiser HD600, Audeze LCD-3F, Mytek Stereo 192 DSD, La Figaro 339, Burson HA-160, Geek Pulse X
Power Supply Corsair AX650
Mouse steelseries Sensei MLG edition
Keyboard Cooler Master QuickFire Pro
Software Windows 7 64-bit Home Premium
Bitfenix has a new case coming out
http://www.youtube.com/watch?v=BGYmUirG3o8&feature=plcp
washd123
50 (0.01/day)
mini itx though
the other one looks cool though maybe to big though
5,976 (1.08/day)
Case Corsair 550D
5,976 (1.08/day)
Case Corsair 550D
washd123
50 (0.01/day)
I'm having a really hard time deciding between the 2 silverstone ones, I like the look of the TJ08E but the other one has 2x 120mm fans in the front I can replace with quieter ones. Also it costs about $20-30 less.
2,468 (0.55/day)
Bulgaria
System Name Sandfiller
Processor I5-10400
Cooling Noctua NH-L9i (92x25mm fan)
Video Card(s) MSI RX 5700 XT GAMING X
Storage Intel 670P 512GB
Display(s) 2560x1080 LG 29" + 22" LG
Case SS RV02
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
washd123
50 (0.01/day)
looks like it won't fit my gpu or most gpus. I'm pretty settled on the silverstone, they're the same inside but different outside and different prices
sneekypeet
Retired Super Moderator
29,409 (4.46/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
180mm fan is already quiet;) The $30 you saved will be spent on the fan swap, so either way it seems they are similar in price to get it the way you want it.
washd123
50 (0.01/day)
didn't think about that, do you think the 180mm would be as quiet as 2 120mm 800RPM fans? each one has a decibel rating of 10dB, while the 180mm is rated from 17-30dB
Norton
14,108 (3.13/day)
Northeast USA
Mouse G300s
VR HMD N/A
The 120's in the PS-07 are pretty quiet. I could only hear them when the front door was open and even then just barely. I have 180's in my FT-01 Fortress and they are silent at 600 rpm :cool:
washd123
50 (0.01/day)
I know pretty quiet, I mean my p180-mini is pretty quiet I want silent. Which is why I figured I'd switch them out
Norton
14,108 (3.13/day)
Northeast USA
Mouse G300s
VR HMD N/A
With the 120mm's in the PS-07 you can always swap them out or slow them down a bit if you don't think they are quiet enough. The 180mm in TJ-08 is silent but your options for using something else is near zero as those fans are only made by silverstone....
washd123
50 (0.01/day)
hm, so even though the TJ08e looks better the ps-07 is probably the better choice since it's cheaper and the fans can be swapped
washd123
50 (0.01/day)
I finally got the TJ08e, I also put in a corsair H60 cooler since it's easier to build with, I replaced the stock corsair fan with a 800rpm slipstream from scythe. I'm adding a second fan soon.
The build is silent the only noise generates from my psu and gpu, well and the hdd's. Overall silent though. It's also running cool I may overclock
Thank you for all the help
Norton
14,108 (3.13/day)
Northeast USA
Mouse G300s
VR HMD N/A
Glad it worked out for you! :toast:
Case and build look great!
