Small LED related question
3,628 (0.62/day)
System Name Ultra 64
Processor NEC VR4300 (MIPS R4300i)
Motherboard proprietary design
Cooling Fanless aircooled
Memory 4.5MB 250 MHz RDRAM
Video Card(s) 62.5 MHz Reality Coprocessor
Storage 32 - 512 Mbit ROM Cartridge
Display(s) 720x576
Case Clear Blue Funtastic
Audio Device(s) 16-bit CD quality
Power Supply proprietary design
Mouse N64 mouse for use with N64DD
Keyboard N64 keyboard for use with N64DD
Ive got some stock fans that came with my case with some awful blue LED's. There brightness isn't the issue but the colour. Now i know i need to make sure the new LED's ill be replacing them with are the same in terms of power draw but i have no idea how to use a multi meter so how can i find the required spec of my new LED's from my old ones so that i can just solder them onto the current wiring?
Many thanks and im afraid electronics isn't my strongest point so i may have got some terms wrong.
12,280 (2.36/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
I wouldn't worry about it. Just solder them in
de.das.dude
Pro Indian Modder
8,784 (1.73/day)
Stuck in a PC. halp.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
yes, just solder them in. use the normal cheap LED variant and you will be fine.
