SMBus Drivers not installed, DMA Controller and an unknown device.HELP :)
Discussion in 'General Hardware' started by LifeOnMars, Sep 29, 2008.
  1. LifeOnMars
    LifeOnMars New Member
    Jun 20, 2008
    2,566 (0.92/day)
    396
    Kettering,Northants. UK
    As the thread title states. In my device manager its showing ATI SmBus has no drivers installed, also the same for the Direct Memory Access Controller. Also an unknown PCI device is showing for PCI slot 1. Help me sort this please as I have no experience with this sort of thing :)
  2. Darren
    Darren New Member
    Feb 27, 2005
    1,936 (0.48/day)
    345
    You've got crucial drivers missing most probably chipset drivers.
    Abit A-S78H requires the following:
    Marvell Gigabit Lan driver
    ftp://ftp.abitshop.com/pub/driver2/marvell_lan/v105133.zip
    AMD-7 Series Chipset Drivers
    http://download.amd.com/Desktop/RAIDXpert2.4.1540.11.exe
    ATI Catalyst™ 8.9 Display Driver for Windows Vista
    http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista32/common-vista32
    LifeOnMars says thanks.
    10 Year Member at TPU
  3. LifeOnMars
    Jun 20, 2008
    2,566 (0.92/day)
    396
    Installed all of those (already had 8.9 catalyst installed) but no change. Anybody else have any help on the matter please?
  4. EastCoasthandle
    EastCoasthandle New Member
    Apr 21, 2005
    6,889 (1.74/day)
    1,507
    It's best to ask the motherboard manufacture. They will tell you what you need to do. Have you tried inserting the CD that came with the motherboard into the cd drive? They have a tendency of installing drivers like that just by inserting them (usually the 1st time you run your OS).
    Here is another idea if for any reason they don't install:
    Find the setup.exe file (or whatever is called) for your chipset drivers. Usually your SMBus drivers, etc may have their own directory so check 1st. Find the install file (usually setup.exe) then right click on it. Choose the option "run as" then choose Administrator. See if that helps...
  5. LifeOnMars
    Jun 20, 2008
    2,566 (0.92/day)
    396
    Yeh installed everything on the CD when I first booted up into windows. Will try getting in touch with Abit and let you know in A Bit :)
  6. Gzero New Member
    Mar 16, 2005
    718 (0.18/day)
    52
    Scotland
    I dont have SMBus installed either on my p5k epu in vista 64, doesn't seem to affect anything.
