Solar/Crank Battery Charger
Discussion in 'General Hardware' started by odameyer, Jan 24, 2013.
  1. odameyer
    odameyer
    Jun 7, 2009
    121 (0.05/day)
    36
    I'm looking for a device that would store power from a solar panel or crank so that I can spend weeks/months off the grid while using my Nexus tablet for terrain mapping with offline maps (or to keep my ham radio powered when the power goes out)
    Something portable
    Does such a thing exist with a crank besides the emergency radios?
    (Sorry if this is the wrong section)
    Also looking for a cheap, high capacity USB battery to keep my smart brick powered.
    [​IMG]
  2. odameyer
    odameyer
    Jun 7, 2009
    121 (0.05/day)
    36
  3. Frag Maniac
    Frag Maniac
    Nov 9, 2010
    3,869 (2.02/day)
    1,091
    All that really is is a high capacity lithium ion battery that allows up to 3 charges, maybe only one or two on a larger screen device like a tablet. A suitable solar charger would cost considerably more, and I've not seen such a device with crank power, except for ones built into radios or flashlights.
    It's hard to advise on this without knowing your max budget. For the duration of time you're talking about it's conceivable lots of cranking or long wait times with lower wattage solar panels would get annoying or even restrictive to how much work you could get done.
    I've seen small cranks for cell phones, but none recommended for larger screen devices such as tablets. Reputable high wattage (15w or more) panels easily run over $200, but I'm sure their convenience would pay off before long.
  4. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    22,179 (5.94/day)
    8,085
    10 Year Member at TPU Crunching for Team TPU More than 25k PPD
  5. Frag Maniac
    Frag Maniac
    Nov 9, 2010
    3,869 (2.02/day)
    1,091
    Eh, carefully read the reviews and product descriptions on such devices. It's described as an emergency cell phone charger. The very first review probably describes it pretty well. 10 minutes of cranking to get just 2 emergency calls made, which were most likely of very short duration. We're also talking about a device that uses far less power than a tablet. Buyer beware.
    Again, you simply can't buy such devices cheap if you expect them to work with what most would consider an acceptable level of convenience for the scenario you're describing.
  6. newtekie1
    Nov 22, 2005
    22,179 (5.94/day)
    8,085
    Thats the downfall of any crank device like this, you can only charge the device as fast as it charges via USB normally. So if your tablet takes 2 hours to charge normally, it will take 2 hours of cranking to charge with a crank charger. It doesn't matter how much you pay for it, that is just the way it is.
    So if you are going to be stationary for a while, solar is the way to go. Or even better, just go buy a small cheap generator...
  7. 95Viper
    95Viper
    Oct 12, 2008
    5,074 (1.89/day)
    2,154
    στο άλφα έως ωμέγα
    There are quite a few options... What are your weight and price requirements.
    Prices can go into the thousands and weight can go from backpacking to towed.
    A little faq page: http://www.ctsolar.com/solarpowerforamateurradiofaq.aspx
    A couple of examples:
    http://www.21st-century-goods.com/solar-generator-and-solar-laptop-kit-sunlinq-25-watt-solar-panel-and-duracell-600-watt-power-pack/
    http://www.ctsolar.com/expeditionsolarpowerpackages.aspx
    It is best to figure out your needs; and, then shop around. Maybe, put together your own personalized kit.
  8. Krazy Owl
    Krazy Owl New Member
    Jan 12, 2012
    900 (0.60/day)
    77
    Montreal
    The only system i know is not really light and potable but you use a car battery and a setup to recharge it.
  9. MT Alex
    MT Alex
    Aug 2, 2009
    3,979 (1.67/day)
    1,789
    odameyer says thanks.
  10. rampage
    May 31, 2007
    1,051 (0.33/day)
    69
    Port Fairy, Victoria, Australia
  11. odameyer
    odameyer
    Jun 7, 2009
    121 (0.05/day)
    36
  12. MT Alex
    MT Alex
    Aug 2, 2009
    3,979 (1.67/day)
    1,789
    No sweat. The nice thing about it is you could pick up another pack of rechargeable AA batteries and always have a set charged.
    I have something similar to the charge pack that uses 9 AA batteries:
    http://ecsys.us/index.php
  13. 3870x2
    3870x2
    Feb 26, 2008
    4,876 (1.68/day)
    690
    Joplin, Mo
    This makes me want to go out and rough it hardcore, like in Far Cry 3, but with an iPad.
  14. odameyer
    odameyer
    Jun 7, 2009
    121 (0.05/day)
    36
    Do enerloops put out enough voltage?
    How about a real tablet with a real OS? :laugh:
  15. 1freedude
    1freedude
    Nov 16, 2007
    557 (0.19/day)
    118
    This is a job i actually did...I used Fujitsu tablet with a Trimble GPS. The tab used Li packs, while the gps used camcorder (full sized, VHS) sealed lead acid (SLA).
    That is the battery that has the best in field workability...you can use almost anything to charge it, just dont let it go over 15v. drawback...heavy.
    Also, look at actual power needed to charge your setup now, in a controlled environment. If that power is not good enough, your charging circuit in the tab might work too hard to regulate. Not knowing exactly what it needs, I would recommend AT LEAST 18000 mAhr capacity (most laptop packs are around 7000). This pack will suit, but recommend at least three of them...one in use, one charging, one for reserve http://californiapc.com/index.php?l=product_detail&p=11512
    edit and this to charge http://www.personalpowerstore.com/index.php?route=product/product&path=44_54&product_id=79
    Where is the area that needs mapping? You are going to need mega sun to charge your stuff.
    Major question>>Will you have transportation?
    Found more. http://www.ctsolar.com/expeditionsolarpowerpackages.aspx
  16. odameyer
    odameyer
    Jun 7, 2009
    121 (0.05/day)
    36
    While that is a mighty good looking setup it would have to wait a LONG time. That'd be something I'd want for a SHTF cache.
    Right now I'm just looking for something small/medium to maintain GPS and radio power (Don't think I'd need more than 5v)
    I would hate to go lugging around $800 worth of panels and batteries only to get clocked in the back of the head with a padlock on a chain and have everything stolen.
    Already have them saved to the tablet, they take up most of the internal storage but I can get a high capacity flash drive to store them on.
    [​IMG]
    Underemployed and annoyed at all the buereaucratic BS involved with being able to drive and own a motor vehicle. So probably not for a long time.
    Mounting those afformentioned panels on a cargo rack would be great.
  17. Frag Maniac
    Frag Maniac
    Nov 9, 2010
    3,869 (2.02/day)
    1,091
    LOL, something told me this was a "fly by night" covert op.
  18. 1freedude
    1freedude
    Nov 16, 2007
    557 (0.19/day)
    118
  19. odameyer
    odameyer
    Jun 7, 2009
    121 (0.05/day)
    36
    I'd prefer to call it "wandering" :ohwell:
    [​IMG]
    [​IMG]
    What on earth is that?
  20. 1freedude
    1freedude
    Nov 16, 2007
    557 (0.19/day)
    118
    new aged firewire! make a fire and charge your shit
  21. Frick
    Frick Fishfaced Nincompoop
    Feb 27, 2006
    12,210 (3.36/day)
    3,448
    No, you're a hobo. I've seen your posts on GN.
    m1dg3t says thanks.
  22. odameyer
    odameyer
    Jun 7, 2009
    121 (0.05/day)
    36
    That kills 3 birds with one sto(n)ve!
    Never seen anything like that.
    On where?
  23. m1dg3t
    m1dg3t
    May 22, 2010
    2,255 (1.08/day)
    518
    Canada
    In Aussieland they call them "Walkabouts"
    Some of which can last up to a couple weeks!
    Make a wind generator and use LiPo batteries from model cars, prolly your best solution. You dirty hippy :p
  24. Frag Maniac
    Frag Maniac
    Nov 9, 2010
    3,869 (2.02/day)
    1,091
    Odd, since the most common use of the word elsewhere is regarding survive in the wilderness rites of passages by Aborigines.
