[Solved][Z77][Asrock Exteme4][What closed loop cooler, to allow top PCIEx1 sound card
Ren_kun
5 (0.00/day)
I currently want to fit 2 x 3 slot graphics cards to my asrock Z77 Extreme4 at the same time fit my Auzentech - AZT-BRAVURA to the top slot, however the h80 i have leaves little room for the sound card to fit into the top slot.
Is there any closed loop coolers that can allow me to fit a soundcard on the top slot? Or any better ideas if you have any?
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
any of them. just orientate it the right way so the tubes are going to be conflicting.
Huddo93
299 (0.07/day)
Perth, WA, Australia
System Name Gaming Rig
Processor i7 2600k @ 4.5GHz
Motherboard Asus Z77 Deluxe-V
Cooling Corsair H100
Memory RipjawsX 8GB @ 2133MHz 11-11-11-30
Video Card(s) EVGA GTX670 SC @ 1300MHz core
Storage OCZ Vertex 4 256GB + 1TB Samsung HDD
Display(s) 23" LG W2343T
Case Corsair 650D
Power Supply Corsiar AX-850
You should have a problem with any of the closed loop WC kits, just make sure you have the tubes running in a way (left or right from the CPU socket) so that it doesn't cover up the PCI slot. Shouldnt have any problems mate :)
Ren_kun
5 (0.00/day)
Hey guys thanks for responding, the problem is that if i orientate the H80 so the tubes are above the fans it will block the PCIE 8pin. Also i dont think there is room if i orientate it left or right. At the momment though the tube comes from below the fan, which as you said would block the PCIEx1.
Are there thinner solutions which could allow the tube orientated from above? Any other input
EDIT:
I looked closer, and i think the H80 can be orientated so the tubes are from the above the fan, Ill find the time to re fix the H80.
Thanks everyone
Huddo93
299 (0.07/day)
Case Corsair 650D
I think you will find this isnt a problem. I installed the H80 in a CM Scout (small case) and didnt have any problems with routing the 8pin with the tubes coming from the top of the fan. They arn't that close.
anoobarak
102 (0.02/day)
Euroland
Processor AMD Phenom II 1090T BE @ 4030MHz
Motherboard Gigabyte GA-990XA-UD3
Cooling Noctua NH-D14
Memory Samsung Green 8GB @ 1896MHz
Video Card(s) MSI GTX 660Ti Power Edition 2 GB
Storage OCZ Agility 3 60GB; 1TB Samsung 2.5"
Display(s) LG Flatron E2241 21.5" LED
Case Thermaltake Commander MS-I Snow Edition
Audio Device(s) Creative Sound Blaster Audigy
Power Supply OCZ ModXStream Pro 600W
if your case has fan mounts on the top of the case, you could mount the rad&fan there also.
