SlipSlice
- Jun 1, 2006
- 770 (0.12/day)
- Indiana
Processor | AMD ATHLON 64 SAN DIEGO 3700@2.42GHZ |
Motherboard | ASUS A8N5X |
Cooling | 1X80MM CASE FAN, 1X80MM CPU FAN, 2X120MM FANS(ONE TAKING AIR OUT..OTHER FOR HARDDRIVE |
Memory | 1.5 GIG, DDR400 CORSAIR |
Video Card(s) | eVGA 7900GS KO |
Storage | 160GIG WESTERN DIGITAL 7200RPM |
Display(s) | Acer 22' Widescreen |
Case | ROSEWILL CASE 5600 SERIES..2 BLUE LED CASE FANS |
Audio Device(s) | SOUND BLASTER LIVE 24 BIT! |
Power Supply | SPARKLE 400 WATT |
Software | WINDOWS XP HOME EDITION..its gr8/LOTS OF GAMES |
I have a soundblaster live 24 bit soundcard thats not possibly working. I have tried reinstalling drivers several times with the old disk that came with it which usually works but doesn't any long i guess. ive tried going to creative.com to check on there drivers for xp but they dont even have drivers for the soundblaster live 24 bit anymore. this all became a problem when i got several viruses on my computer which are gone now, and deleted my sound drivers or messed them up somehow. i used a driver cleaning program to get rid of the old ones and like i said tried reinstalling the drivers several times, but when i go to conrol panel>sound>, everything is always greyed out. I don't know what to do...anybody have any suggestions i have and havent had sound for over 2 weeks now.
thanks for any help.
i know the soundcard works because if i got to hardware on audio and click on soundblaster audio it says (this device is working properly). So im thinking its just a driver problem but im not definately not sure.
ps. sorry if this threads in the wrong position of the forums, im not sure if its a software problem or a hardware problem.
