speedfan won't detect speed of case fan
Uptime73
109 (0.02/day)
Columbus, Ohio USA
System Name custom built clone
Processor AMD Phenom 9950 Quad Core (Agena)
Motherboard ASUS M3A78-EM
Cooling Zalman CNPS9700 LED
Memory OCZ Fatal1ty PC2 8500 4 GB (2 x 2GB)
Video Card(s) Visiotek ATI Radeon 3650
Storage Western Digital 320 GB SATA II hard drive
Display(s) Proview CRT
Power Supply 475 watt not sure of brand
Software Vista Ultimate Edition x64, Service Pack 2
Hello all. I just installed an Antec case fan and when I brought up speedfan, it doesn't detect the speed of the case fan, although BIOS doesn't either. If BIOS doesn't detect speed of case fan, will speedfan still be able to detect it? Thanks.
- Josh
sneekypeet
Retired Super Moderator
29,409 (4.47/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Case fans will not be monitored by any software if it isnt plugged into the motherboard!
Uptime73
109 (0.02/day)
Columbus, Ohio USA
sneekypeet
29,409 (4.47/day)
System Name EVA-01
it might then no guarantees tho. Open it up and look at some of the AUX fans, it may be there!
boogah
887 (0.15/day)
Houston
System Name Core i7 WS
Processor i7 920 D0 @ 4.2 GHz
Motherboard ASUS P6T WS Professional
Cooling Thermalright Ultra 120 Extreme RT1366
Memory 6gb 3x2gb Crucial DDR3
Video Card(s) Firepro V8700
Storage Velociraptor 300gb in raid0
Display(s) 2x Dell Ultrasharp 24"
Case Antec Twelve Hundred
Audio Device(s) onboard sound
Power Supply Corsair HX1000
Software Windows 7 64-bit
well if the bio's can't see it speedfan can't see it.
ktr
7,404 (1.12/day)
Speedfan looks at bios for the sensor addresses. So if the bios doesn't show the rpm, so wont speedfan.
Uptime73
109 (0.02/day)
Columbus, Ohio USA
I think BIOS show speed of cpu fan only
Odin Eidolon
920 (0.16/day)
Rockclimbing somewhere in Italy
Processor e6300 @ 3000, stock Volts
Motherboard msi p35 neo2-FIR
Cooling HDT-1283
Memory 2gb tracers 1066 micron d9GMH, cooled by a modded CoolIt Memory Cooler
Video Card(s) HIS 4850 ICEQ4
Storage WD Caviar 16 320gb WDAAKS + 640gb WDAAKS
Case CM RC-690 sligthly modded
Power Supply Bequiet darkpower PRO 850W (say overkill? :D)
Software kubuntu 8.10 + Windows XP, soon Windows 7 too
mh my board has a lot of fan speed sensors, and the fans are plugged into the mobo, but i cant monitor nor see fan speeds... why?
p.s. sorry i am stealing your thread, i have the same problem as you
amajmon
19 (0.00/day)
Do you read your mbo manual you will find right cooling fan connector. If you don't put in right connector bios or speedfan can't read it.
Odin Eidolon
920 (0.16/day)
Cooling HDT-1283
i did: no way
59 (0.01/day)
Processor Intel Core i5 3570K @ 4,1 Ghz
Motherboard Asus P8Z77-M Pro
Cooling Gelid Tranquillo rev.2
Memory 2x4GB Corsair 1600Mhz DDR3
Video Card(s) Sapphire Radeon RX580 8 GB
Storage Samsung 850 EVO 500GB SSD, Western Digital WD7501AALS; Seagate Barracuda Green 2000DL003
Display(s) Philips 272B7Q
Case Fractal Design Arc Mini
Audio Device(s) Asus Xonar DX
Power Supply Seasonic S12II-520 Bronze
Mouse Logitech MX Master
Keyboard Logitech MK540
Software Windows 10 64-bit
Is your fan connected with 3 cables ? The third (i think yellow) cable is the RPM monitoring, however many fans come only with 2 cables (red and black) and those cant be monitored.
Odin Eidolon
920 (0.16/day)
Cooling HDT-1283
yeah sure i know that, everything is 3 wired. but it seems i'm stealing this thread. Sorry!
amajmon
19 (0.00/day)
Sory seems thath server make double post thats all.
Odin Eidolon
920 (0.16/day)
Cooling HDT-1283
done. you already asked that!
