Spilled Coffee on my Graphics Card - Need help please!
12,280 (2.36/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
Do you turn the heat off on the dish washer?
The reason I ask is its a pain to clean a MB. Sticking it in the washer would be nice in some cases
cdawall
where the hell are my stars
27,680 (4.27/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
Yes you turn the heat off
Mussels
Freshwater Moderator
58,413 (8.18/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
i know that nvidia cards put out a lot of heat, but using one to warm your coffee is just insulting (to the coffee)
as others have said - you need to clean it and have it dry. heat is bad, as is powering it up while still 'dirty'
de.das.dude
Pro Indian Modder
8,785 (1.73/day)
Stuck in a PC. halp.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
WTF, Put the PCB or the cooler in the Dishwasher? Neither should not come in contact with a liquid(this is why he is in this position). Um, the card was on when the coffee hit it, so the damage is done, if any. Turning it on after a brief cleaning will not do any additional harm other than exists already.:shadedshu
lol. W1zzard taught me this :rolleyes:
he does it too :roll:
atfirst i was also like :shadedshu
make sure that your PC is drained off of any charge. if the capacitors still have charge in them, it WILL short when you put it in the washer.
Aquinus
Resident Wat-man
13,147 (2.94/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Most motherboard caps don't hold enough to keep a charge more than a couple seconds, internal resistance helps with this. Just an FYI.
Definitely make sure to take out the clock battery if you're doing a mobo though. :)
Mobix
5 (0.00/day)
First off DO NOT put the video card in the dish washer or submerge the entire card in any kind of liquid. If the warranty sticker on the back of the video card gets damage and is not legible it WILL void your warranty.
Get some isopropyl alcohol on a cotton cloth and clean off the sticky residue from the area.
Take some clear unblurry pictures of the card and have them ready to be emailed.
Contact EVGA support, if you are in North America they have 24hr tech support and would be able to help you setup and RMA.
Liquid damage isn't usually covered by warranty but if the damage isn't severe you'll be covered. Unfortunately you wont know for sure until their RMA dpt inspects it.
Isn't the stained sticker kind of a giveaway?
2,555 (0.40/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
The extremely small amount of chlorine and the extremely short exposure time won't lead to any oxidation.
I've run plenty of PCBs through the dishwasher, mostly motherboards though, only one graphics card, and they all come out just fine. And there isn't any soap residue, the whole point of the dishwasher is to be very effective at removing all residue. Your dishes don't come out covered in soap residue, do they? If they do, you need a new dishwasher(or use less soap).
And yes, obviously this will likely destroy any stickers on the card, so the warranty will be totally gone. But with the warranty sticker already covered in coffee according to the original post the warranty is gone already. EVGA isn't going to warranty the card with the sticker totally brown like that.
It doesn't need to be powered. The oxygen in the atmosphere reacts with... oh nevermind. This is gradeschool chemistry. :rolleyes:
Morgoth
Fueled by Sapphire
4,226 (0.69/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
put the card in hot coal that wil fix it for sure!
2,665 (0.45/day)
Switzerland
Processor i9 9900KS ( 5 Ghz all the time )
Motherboard Asus Maximus XI Hero Z390
Cooling EK Velocity + EK D5 pump + Alphacool full copper silver 360mm radiator
Memory 16GB Corsair Dominator GT ROG Edition 3333 Mhz
Video Card(s) ASUS TUF RTX 3080 Ti 12GB OC
Storage M.2 Samsung NVMe 970 Evo Plus 250 GB + 1TB 970 Evo Plus
Display(s) Asus PG279 IPS 1440p 165Hz G-sync
Case Cooler Master H500
Power Supply Asus ROG Thor 850W
Mouse Razer Deathadder Chroma
Keyboard Rapoo
Software Win 10 64 Bit
i think is the PCI 16x connector on the motherboard that is full of coffe... You have to get a new motherboard sorry man
11,690 (1.73/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Storage Samsung 990 2TB, 2 SP 2TB SSDs and over 10TB spinning
Display(s) 56" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Go buy a gallon of deionized water and get a plastic tub and old tooth brush.
Remove the cooler and give it a scrub.
When done give it a few shakes and either put it in the oven on some tinfoil for a couple hours at 180F to dry it or use a hairdryer. Reapply thermal compound and reattach cooler.
1,556 (0.31/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX, 4.8 GHz cache clock | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB NVMe+480GB SATA SSD+2 TB HDD | Crucial P5 1TB, Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE | Realtek ALC1150 (Supreme FX)
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
Nothing will happen. Just take some Isopropyl Alcohol and clean the PCB. No need to remove the heatsink. The Coffee stain will go with the IPA. Then check you card and let us know.
de.das.dude
Pro Indian Modder
8,785 (1.73/day)
VR HMD ;_;
deionsed water? that even exist? lol. cause as soon as you expose it to the atmosphere it will get ionised. lol.
and the sticker wont be stained if you dont scrub on the sticker. nothing happens. i have washed my GTS 450, my old 4650 and a friends 5450 before. they are all cool.
just use water that is pure water, not salty hard water or iron rich water. in that case its best if you can get some distilled water.
1,445 (0.34/day)
Israel
Processor AMD Ryzen 7 5800X
Motherboard B550 Aorus PRO V2
Cooling Corsair H115i RGB Platinum
Memory Gskill Trident Z Neo 3600 2x16GB
Video Card(s) MSI RTX 3070 Trio X
Storage WD Blue SN550 1TB NVME/Supertalent Teranova 2x1TB
Display(s) Acer XV340CK
Case Corsair 4000D Airflow
Power Supply Corsair HX850i
Keyboard Logitech G513 Tactile
Will removing the stained sticker void your warranty?
Mobix
5 (0.00/day)
Removal and or Defacing of Serial/Part number sticker(s) on ANY EVGA products WILL void ALL warranties. All products ship from EVGA with a serial sticker. I'm guessing that's a yes
HammerON
The Watchful Moderator
8,397 (1.52/day)
Up North
System Name Threadripper
Processor 3960X
Motherboard ASUS ROG Strix TRX40-XE
Cooling XSPC Raystorm Neo (sTR4) Water Block
Memory G. Skill Trident Z Neo 64 GB 3600
Video Card(s) PNY RTX 4090
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard Corsair K70
Never considered putting pc parts in the dishwasher:laugh:
I learn something new everday:toast:
1,445 (0.34/day)
Israel
any progress? maybe you should just send it to EVGA as it is.
5,654 (1.15/day)
System Name Space Station
Processor Intel 13700K
Motherboard ASRock Z790 PG Riptide
Memory Corsair Vengeance 6400 2x16GB @ CL34
Video Card(s) PNY RTX 4080
Storage SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB
Display(s) LG C3 OLED 42"
Case Corsair 7000D Airflow
Audio Device(s) Yamaha RX-V371
Power Supply SeaSonic Vertex 1200w Gold
Mouse Razer Basilisk V3
Keyboard Bloody B840-LK
Software Windows 11 Pro 23H2
I say get some denatured alcohol. It's cheap (as little as $7 a quart), is stronger than isopropyl, leaves no residue, and evaporates much quicker. Along with that (if you don't already have them) you can get a small fine bristle paint brush or foam trim brush and a good rag to clean and blot. All can be had at your local woodworking or DIY home store.
The key thing is carefully cleaning around that which needs to remain undamaged.
5,654 (1.15/day)
I would leave that sticker alone, don't even get it wet, period. It looks like the digits and bar code are still legible, you want to keep it that way.
And again, denatured alcohol is better than isopropyl. It's pure with nothing to leave a residue. Also, spray cleaners are convenient, but they can also cause spray to go where you don't want it to.
176 (0.04/day)
System Name For now
Processor Intel i7-4790K
Motherboard ASRock Extreme9 Z97
Cooling Corsair H100i
Memory Kingston HyperX
Video Card(s) Asus GTX 980 Strix x 2
Display(s) Overlord
Case Corsair 900D
Power Supply Corsair AX1200i
Think he meant distilled water.
But yeah buy some gallon jugs of Distilled water, warm it up a little, take apart the card and scrub way with a soft toothbrush.
If air drying let it dry for a good 48+ hrs.
