Strange problem overclocking Sapphire X800 GTO2 w/ AtiTools
Discussion in 'Graphics Cards' started by PooPoo, Nov 3, 2005.
  1. PooPoo New Member
    Nov 3, 2005
    7 (0.00/day)
    0
    Hi Guys,
    I am having a problem oc'ing my X800 GTO2 using AtiTools 0.24...
    I started out finding the Max Mem which got me up to around 600, but when I tries to find the Max Core... value starts going up from the default...450 to around 456... then starts dropping to ~420, 419, 410....etc and I stopped it as I found it very strange.
    Do you guys have any idea why my core speed drops so much? Again, I was finding the Max Core...
    A64 3200+ | X800 GTO2 Cat 5.10 | Asus A8N5X | 1024MB
    Thanks in advance.
  2. observing New Member
    Oct 29, 2005
    2 (0.00/day)
    0
    Do you open the Sapphire's tool which controls the core and fan's speed?
    I'm using AtiTools 0.25 beta 8,oc'ing my X800 GTO2 at 560/1250.I have no problem.
    3000+@2.25G | X800 GTO2 Cat 5.9 | DFI Lanparty NF4 Ultra-D | G.Skill 512MB 550 × 2
  3. PooPoo New Member
    Nov 3, 2005
    7 (0.00/day)
    0
    observing, thx for your tips... i installed the sapphire's tool and set the fan speed to 100% and ran atitools again last night. this time the core speed finally goes up but it stays around 467... i thought it could at least do x850xt speed... maybe have to try it again.
    actually, i have a quesiton...is it ok to leave the fan speed at 100% 24/7? does it hurt the card in the long run?
  4. observing New Member
    Oct 29, 2005
    2 (0.00/day)
    0
    which bios are you using now?
    i'm using x850 xt's bios.you can see the zip.the file is x850.bin,that is just edited.i'm using it stably.perharps you can try!:)
    • x800.zip
      File size:
      137.3 KB
      189
  5. PooPoo New Member
    Nov 3, 2005
    7 (0.00/day)
    0
    thx for the bios... before i try i must ask you some questions...
    1. my sapphire x800gto2 came 16p pre-unlocked, maybe this is for the hong kong market... will that mess up using your bios?
    2. i assume your x850xt bios set the core, ram & and fan speed like the real x850xt, am i correct?
    3. have u try the x850xtpe bios yet?
    4. how fast does your fan run now?
  6. Thermopylae_480
    Thermopylae_480 New Member
    May 27, 2005
    3,686 (1.01/day)
    393
    Little Rock Arkansas, United States
    You can use ATI Tool to set up how fast your fan will go at certain temperatures. For example if your card idles at 44~C have your fan spin slower around that temperature range. Then you can set it to increase as the card heats up to load speeds until it reaches 100%. There is really no need to have it run at 100% 24/7.
Share This Page
