[Case Gallery] Super Piston Custom Water Cooling
Discussion in 'Case Mod Gallery' started by crack legion, Jan 11, 2011.
  1. crack legion Guest
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Mods:
    I made my own case similar to Edelweise from million dollar PC hehehe, I made my own water block came from a motor cyle piston, Accumulator from a flower vase cylinder, Custom Cable management using spaghetti tube, i made my own SATA long wire 1.5 meters long on the HDD and DVD-RAM,
    Special thanks to "Virgilio Cabahug jr." for machining my Piston Cover and Connectors, and "Jay (KH0UJ) Nayon" for drilling the Accumulator Glass and setting up the wirings, "Rene Blanco" for the Custom Paint Job and specially me hehehehe
    10 Year Member at TPU
  2. crack legion Guest
    My Radiator came from a minivan heater core, and i used a submessible aquarium pump 220VAC 800L/Hour, My core temps are 6 celsius in each core, coolant is from caterpillar heavy equipment, The case is made of plywood, body filled and i used automotive paint for finishing
  3. vir377 Guest
    Owss :)
    I no that
  4. vir377 Guest
    6-10 degre's cold
  5. SrGnT Chaos New Member
    Dec 4, 2010
    31 (0.02/day)
    0
    Mount Dora, FL
    Wtf
    First off, it's "I know that" and second, how do you know anything unless he either explained it all in the description or you assisted him in building it. Post comments that at least make sense or don't post at all.
  6. SrGnT Chaos New Member
    Dec 4, 2010
    31 (0.02/day)
    0
    Mount Dora, FL
    He said 6, not 6 - 10, so I'm gonna guess he knows what he is talking about in reference to his own equipment unless you are referring to your rig in which that should have been explained.
  7. SrGnT Chaos New Member
    Dec 4, 2010
    31 (0.02/day)
    0
    Mount Dora, FL
    Awesome setup...........9/10.............nothing more creative than "real" custom parts
  8. ensabrenoir
    ensabrenoir
    Apr 16, 2010
    1,446 (0.68/day)
    313
    Great job! Total representation of what this sight is about...and an Autobot too +1 point! Crack legion sounds decepticon-ish though. Anyway cool rig.
  9. pentastar111
    Aug 18, 2006
    993 (0.29/day)
    31
    Los Angeles...U.S.A
    That is very cool 10/10
  10. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.52/day)
    640
    Wangas, New Zealand
    A piston to circulate the water.....
    I like it.
    I wonder how a rotary powered one would be possible.
    Not that I am into those noisy engines in the first place.
    I would like to see a water cooler where you could actually see the pistons moving.
    Seeing the mechanical parts regardless of how uneconomical it maybe.
