Swapping PC parts, how does this system look.
Discussion in 'System Builder's Advice' started by CDdude55, Jul 20, 2008.
  1. CDdude55
    CDdude55 Crazy 4 TPU!!!
    Jul 12, 2007
    8,179 (2.61/day)
    1,277
    Virginia
  2. calvary1980
    calvary1980 New Member
    Dec 26, 2007
    1,801 (0.61/day)
    310
    Toronto, CA
    empty.
    - Christine
  3. CDdude55
    Jul 12, 2007
    8,179 (2.61/day)
    1,277
    Virginia
    Sorry here are the specs:
    Intel Core 2 Duo E8400:http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
    2GB Gskill DDR3http://www.newegg.com/Product/Product.aspx?Item=N82E16820231149
    Diamond 4870http://www.newegg.com/Product/Product.aspx?Item=N82E16814103061
    PC Power and Cooling 750Whttp://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
    WD Caviar HDDhttp://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
    Need a motherboard that will work with that ram and CPU out of the box. But i dont know which one.:confused:
  4. farlex85
    farlex85 New Member
    Mar 29, 2007
    4,829 (1.49/day)
    637
    A p45 would. Give you crossfire for a reasonable price as well. Most boards released in the last 4-5 months in the p45/x38/x48 category would be able to do 45nm out of the box. Most others should too, but if you get one that's been around for a while it's possible it will come w/ the old bios.
  5. CDdude55
    Jul 12, 2007
    8,179 (2.61/day)
    1,277
    Virginia
  6. CDdude55
    Jul 12, 2007
    8,179 (2.61/day)
    1,277
    Virginia
    You know what i may just go with a good DDR2 motherboard. It will save me alot of money on memory. But whats a good DDR2 board that supports 45nm and my RAM(the ones in the system specs) out of the box? For a good price.
  7. Kenshai
    Mar 2, 2008
    1,646 (0.57/day)
    218
    Raleigh, North Carolina
    If you don't plan on Crossfire, a good newer revision P35 or a P45 board would do you fine.
    EP45-DS3L
    There is also a P35 version of that motherboard very similar here.
    Either one of those wouldn't need a bios update to run your E8400.
    Also worth mentioning is the X48 board but it's a little pricier.
  8. CDdude55
    Jul 12, 2007
    8,179 (2.61/day)
    1,277
    Virginia
    I may plan on doinf crossfire later. Maybe get another 4870.
  9. CDdude55
    Jul 12, 2007
    8,179 (2.61/day)
    1,277
    Virginia
    bump
  10. erocker
    Jul 19, 2006
    41,046 (11.76/day)
    16,143
    If you plan on doing crossfire later and want the best performance with less troubles get a X48 board. Gskill Pi PC2-9600 ram is the best stuff that's out right now, if you can find it.
  11. farid
    farid New Member
    Feb 5, 2008
    158 (0.05/day)
    5
    Valencia, Venezuela.
    I think that ASUS P5Q if you dont want Xfire and ASUS P5Q-E if you want Xfire, both uses the P45 chipset and Ive heard that the P5Q OC very well.
    Good Luck :D
    CDdude55 says thanks.
