Swiftech Launches the Apogee Drive II CPU Water-Block with Integrated Pump
Discussion in 'News' started by Cristian_25H, May 29, 2012.
  1. radrok
    radrok
    Oct 26, 2011
    3,098 (1.97/day)
    850
    Yes, I agree, I have two Laing DDC500 on parallel and the head pressure they yield is scary.
    Anyway not to be a Koolance fanboy, years ago I would never touch any of their products but today they are almost comparable to Swiftech, their quality has really step up.
    MT Alex says thanks.
  2. cadaveca
    cadaveca My name is Dave
    Apr 10, 2006
    15,046 (4.18/day)
    8,554
    Beaumont, Alberta
    I agree.
    However, both this block/pump combo, and the ApogeeHD block and rad set, are soemthing else entirely fro mwhat koolance offers IMHO. You very nearly get easy high-end water setups, that are nearly as easy to assemble as the AIO coolers from Corsair, Antec, and the like, while offering functionality no other offers.
    I posted about this unit before the news item hit...I've been paying close attention to Swifttech as of late, ebcuase they sure do have some good stuff this year!(Nevermind there's not much else new when it comes to watercooling right now:laugh:).
    radrok says thanks.
  3. radrok
    radrok
    Oct 26, 2011
    3,098 (1.97/day)
    850
    Yeah, the only new thing about watercooling that has touched us lately is the introduction of Monsoon free center compression fittings and they are damn sexy, thanks again Dave for pointing me to em.
    And this pump+highend block combo is a very awesome and welcome piece to the watercooling scene, do you imagine how this will integrate into microATX builds?
    People didn't know where to put the res+pump combo because there isn't so much space in those cases, now you can get a clean small build with this.
  4. cadaveca
    Apr 10, 2006
    15,046 (4.18/day)
    8,554
    Beaumont, Alberta
    ;) Now you're thinking. I've kinda been on the ball with watercooling stuff as of late...been a whiel since I bothered with anything more than Corsair AIO units, and if I'm gonna invest the kid of $$$ that a proper setup involves, I want to make sure to be getting the right kit.
  5. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.11/day)
    3,777
    Not anymore. Koolance runs with the big dogs now. Just look at reviews for their full coverage GPU blocks, CPU360, and DDC/MCP accessories.
  6. MT Alex
    MT Alex
    Aug 2, 2009
    3,980 (1.67/day)
    1,790
    Point well taken. I don't think, however, that he was referring to any of their revamped parts. For the $200 he mentioned, I pictured the old Koolance top mounted aluminum rad/shroud with integral crappy pump and crappy block, hence my comment.
    In case you all were planning on hanging me out the window by my feet:
    cadaveca says thanks.
  7. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.11/day)
    3,777
    lol
    And yeah, their old parts were definitely shit.
  8. adrianx New Member
    Jan 9, 2008
    324 (0.11/day)
    22
    Bucharest ROMANIA
    the problem it is with the block pomp, more precise with that 2 connectors in form of letter J
  9. function69 New Member
    Oct 28, 2010
    60 (0.03/day)
    10
    I'm a noob in water cooling, so the only other part that I will need for this to run is a radiator? And I'll need to pay for it separately? Also, what's the benefit of having the pump on the block vs. the radiator?
  10. adrianx New Member
    Jan 9, 2008
    324 (0.11/day)
    22
    Bucharest ROMANIA
    function69 it is simple the space that pomp can take in your case (or outside). the water pressure at sort distance of the pomp is bigger. the pressure will decrees in relation with the length and diameter of the water circuit.
    the difference is not a big one at this little pomp.
    the bad parts:
    -the pomp generate vibrations
    -the pomp can get hot
    -the pomp connectors are tricky
    in this system the connectors of the waterblock ar in L shape. this is the real problem because the connectors down get directly attached to the watterblock. (there are no filet). if you see the pictures there are a sets of screws that kepp the connectors pressed to the waterblock. this is not a good ideea.
  11. Sinzia
    Oct 5, 2010
    861 (0.44/day)
    217
    This combines two parts of a loop, the cpu block and pump. You'd still need a radiator, tubing, and either a res or T-line, either of which are fine.
    All quality blocks are held together with screws and bolts, its the low quality ones you can't take apart.
  12. adrianx New Member
    Jan 9, 2008
    324 (0.11/day)
    22
    Bucharest ROMANIA
  13. sy5tem
    Nov 13, 2004
    449 (0.11/day)
    48
    Canada/quebec/Montreal
    AHHHHHHHH that screw!...
    still this good for a small WC started kit :p
    10 Year Member at TPU
  14. Sinzia
    Oct 5, 2010
    861 (0.44/day)
    217
    Its a dual position fitting that's held in with screws. I don't see much of an issue with that, considering EK uses something quite similar for the FC-Bridge SLi/Crossfire manifold.
    This is one situation where the user needs to have a bit of common sense and all should be ok.
  15. Delta6326
    Delta6326
    May 21, 2008
    3,984 (1.41/day)
    724
    Iowa, USA
    Now to have one on the cpu and mod one to the gpu connect them and you got a sweet wc loop.
  16. Sinzia
    Oct 5, 2010
    861 (0.44/day)
    217
    That's a 35x pump on that, it's already good enough to push several GPU blocks, but it would be pretty cool to see them in a "boost pump" kind of setup.
  17. Delta6326
    Delta6326
    May 21, 2008
    3,984 (1.41/day)
    724
    Iowa, USA
    Then you can haves them both at low rpms. To make it a quite wc loop.
  18. radrok
    radrok
    Oct 26, 2011
    3,098 (1.97/day)
    850
    Man I think you don't realize how much powerful is the 35x :D
