Taking a reg case and making it ROCK!
Discussion in 'Project Logs' started by MKmods, Feb 26, 2008.
  1. CyberDruid
    CyberDruid New Member
    Sep 23, 2007
    2,888 (1.04/day)
    1,100
    On top of a mountain
    Someday I bet you will ;)
    MKmods says thanks.
  2. SkyKast
    SkyKast
    Oct 26, 2008
    2,099 (0.88/day)
    358
    massachusetts
    thanks I am getting some from them but NOOOOO they are out of hex mesh!
  3. Thrackan
    Thrackan
    Oct 10, 2008
    3,482 (1.46/day)
    656
    Mark, I see you bend alum like it's nothing, but how would you get proper results?
    I saw your little tutorial on bending Acrilyc/Plexi, so I think using some proper (wooden) clamping will do to prevent damaging.
    Problem is my alum plate is rather thick (1-1.5mm) and has structure on one side. I think I'll make tear marks by just bending it. Would heating up help?
  4. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.18/day)
    1,748
    Nevada
    The panels I use are .032 to .060 thick.(similar to 1 to 1.5mm) I have a 36" metal brake now as well as a 18" bench model.
    It is not a box brake so it can be a challenge doing several bends and for them I clamp blocks of hardwood and bent it like the plastic over the edge of my desk.
    Heating may be a possibility but I have never tried it, I would be afraid of warping the metal.
    see if you can track down one of these
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=39103
    Thrackan says thanks.
  5. Thrackan
    Thrackan
    Oct 10, 2008
    3,482 (1.46/day)
    656
    Well that was a quick one!
    I think my biggest concern is the structure on the plate will tear or damage:
    [​IMG]
    I also saw this pic:
    [​IMG]
    And found out you put a slimline drive in there. I couldn't find a worklog though. Can you share with me how you fastened that drive? :D
    MKmods says thanks.
  6. CyberDruid
    Sep 23, 2007
    2,888 (1.04/day)
    1,100
    Not to hijack but I have found that you can heat the metal with a torch then let it cool and it will be annealed (softer) and almost too easy to bend. Heating it again all over and quenching it with wet rags or a bucket of water will harden it somewhat again.
    SkyKast and MKmods say thanks.
  7. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.18/day)
    1,748
    Nevada
    Thanks CD for the tip.
    LOL because the hole in the faceplate was very snug all I needed to do was place a piece of Velcro on the top of the DVD drive and Velcro it to the alum plate.
    One other thing about the alum bending, try it on a small (scrap ) piece first to see how it works.
  8. Thrackan
    Thrackan
    Oct 10, 2008
    3,482 (1.46/day)
    656
    Velcro! That didn't even cross my mind! Brilliant solution :D
  9. Thrackan
    Thrackan
    Oct 10, 2008
    3,482 (1.46/day)
    656
    And thanks again for the bending lesson, I just tried a small piece.
    I totally forgot about the curve you bend in somehow :D so no damage at all to the structure.
    We've got one of these in the shed, dunno what the english word is:
    [​IMG]
    but that works like a charm! 90 degrees bends are a piece of cake!
    Now I've got even more ways to work out the several bracket types I need.
    MKmods says thanks.
  10. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.18/day)
    1,748
    Nevada
    bench top vise, and congrats.
  11. SkyKast
    SkyKast
    Oct 26, 2008
    2,099 (0.88/day)
    358
    massachusetts
    I'm sorry I just read through the metal bending conversation and I might of missed it but how do you got nice round bends? It seems like a vise would make them pointed
    MKmods says thanks.
  12. Thrackan
    Thrackan
    Oct 10, 2008
    3,482 (1.46/day)
    656
    I got a nice curvy bend... I guess the material will do that for you if you bend it nicely :)
    Pointed bent metal = broken metal I guess.
    MKmods and SkyKast say thanks.
  13. SkyKast
    SkyKast
    Oct 26, 2008
    2,099 (0.88/day)
    358
    massachusetts
    oh ok sweet, thanks
  14. CyberDruid
    Sep 23, 2007
    2,888 (1.04/day)
    1,100
    True...the material itself deteremines the radius of your curve up to a point. If you round the edge of a piece of scrap wood first and clamp the metal to that it will sort of follow the curve in the scrap.
  15. SkyKast
    SkyKast
    Oct 26, 2008
    2,099 (0.88/day)
    358
    massachusetts
    right good thinking thanks for all these helpful tips :D
Share This Page
