temp sensor and fan control on X800gto
Discussion in 'Graphics Cards' started by Phelllip, Aug 1, 2006.
  1. Phelllip New Member
    May 25, 2005
    59 (0.02/day)
    0
    Montreal, Qc, Can
    Is there a temp sensor and a fan control on a Powercolor x800gto agp?? When i open ATITool and go in settings, I can't get to the temp monitor or fan controller
  2. stevorob
    stevorob New Member
    Feb 27, 2006
    844 (0.27/day)
    24
    NC
    Are you using .25 beta? The GTO only seems to work with .24
    Get .24 and see if that works.
  3. Phelllip New Member
    May 25, 2005
    59 (0.02/day)
    0
    Montreal, Qc, Can
    i've tried both and none works
  4. roadtonowhere08 New Member
    Jun 25, 2006
    10 (0.00/day)
    0
    No, unfotunately, there is not any way to monitor temps or fan speed as the chip required is missing on the front of the PCB to the left of the GPU. Also, as if it was bad enough, the BIOS was locked (for me at least), so I could not change anything. I had the same one and was pissed when I found that out. I returned it and got a Sapphire X800GTO. If this is a deal breaker for you, I suggest you do the same.
Share This Page
