The best water cooling for cpu
5,123 (0.94/day)
North of Germany
System Name Nexus PC
Processor Intel Xeon E3-1231 v3, 3600 MHz
Motherboard Gigabyte GA-H97-HD3
Cooling Thermalright Macho V2
Memory 24GB DDR3, 1400MHZ CL8
Video Card(s) Sapphire Radeon R9 290
Storage Samsung EVO 960 250gb, EVO 850 250gb, Vertex 3 128gb. 2 TB of Rotational.
Display(s) 1xAsus MX299, 2x Asus MX239, Oculus Rift CV1
Case Sunflower Tower
Audio Device(s) C-Media CMI8738/C3DX
Power Supply Corsair TX850
Mouse Cyborg R.A.T. 7
Software Win7 64Bit Ultimate
Yes you can. I use only distilled water. No additives at all. It performs better than anything else.
All this arguing is moot however because of this:
F430 - we need to know how much you plan to spend.
WORD! i use deionized water brand "robby rob", and never had problems with algae,or stuff;)
no additives so far.
Wile E
Power User
24,318 (3.79/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
Oh, I did want to add, do not mix aluminum and copper in your loop. It will cause corrosion, even with additives. Additives just slow the process, not eliminate it.
And cars with aluminum rads also suffer from this corrosion. That's why cooling systems need to be flushed periodically. ;)
JrRacinFan
Served 5k and counting ...
20,073 (3.21/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
Only distilled here. Nothing added.
Price vs performance: Apogee GTZ. Going all out: HK.
Wile E
Power User
24,318 (3.79/day)
I'd say the EK Supreme LT is the better buy over the GTZ.
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
5,123 (0.94/day)
North of Germany
i would step up to the hk lc at least. just for the much better flow rate.
Wile E
Power User
24,318 (3.79/day)
Still both hella blocks for the price tho.
Agreed. Swiftech stuff has good bang for the buck. The EK just happens to eek it out this time.
Wile E
Power User
24,318 (3.79/day)
10,233 (1.70/day)
Austin Texas
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case SLIGER S620
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard RoyalAxe
Wile E
Power User
24,318 (3.79/day)
guys. You need distilled water and a biocide such as copper sulfate or silver.
No you don't. That's only if you plan to never tear down the loop. I have no problem doing a flush every now and again. Not to mention, we tend to change hardware a lot. Although, my current loop has been together for over 6 months, with no signs of algae or degradation of performance. 6 months is a long time for me.
5,123 (0.94/day)
North of Germany
i used the same water nearly a year, with minimal addition of the water that was lost due to evaporation thru the hoses.
if you only run water alone, in a sealed loop, there will be very minimal change to the coolant overtime;)
